Sketch curve resolution
All  1  2-4
10682.2 In reply to 10682.1
Hi routb3d,
> Anyone know of a script that I can use to set the resolution of a sketch curve?
There is not currently any way for a script to adjust this, can you describe a bit about
what you're trying to do or what problem you're seeing?
> Also, the repeat check box in the sketch curve ui is missing in version 5 beta, and I'm
> assuming it has been replaced by some other method. Anyone know anything about this?
Hmm, no it's not intended to be missing or replaced by anything else and I can't repeat the
problem of it not showing over here on 3 different machines.
What OS are you running on, and have you done any customization of the UI perhaps?
10682.3 In reply to 10682.2
The checkbox just reappeared after relaunching v5.. Strange. I'll try to be more diligent in testing prior to asking in the forums.
I'm using the sketch tool to annotate and the curve seems to be forming to smooth for my writing speed. Letters are a bit illegible.
Isaiah
10682.4 In reply to 10682.3
Hi Isaiah,
Does it behave differently if you move your mouse a little slower?
Show messages: All  1  2-4
