Radio Buttons
All  1  2-3
10656.2 In reply to 10656.1
Hi Brian, MoI's regular UI doesn't happen to use a radio button anywhere so there isn't a predefined control for it.
The reason it's not been used is that it tends to take up a lot of space. What is used instead is a drop-down control which also allows for one active option showing out of a set.
The drop-down is a <select> control, and yes the Build option in LineWeb.htm is one example.
But it is certainly possible to cook up a radio button using some HTML and script, let me know if you want me to make an example for that.
10656.3 In reply to 10656.2
Thank you for responding.
Space is a premium, so a Build dropdown menu will work fine, for selecting the type of Braid weave to create.
(The CheckBox method is not appropriate for the script modification.)
Show messages: All  1  2-3
