V5 Beta test
 1-16  17-36  37-56  57-76  77-84
10653.57 In reply to 10653.53
Hi Michael, yes it's a magic mouse, i'll check your solution at work this morning.
Thank you.
Moujiik
10653.58 In reply to 10653.57
OK it's working now.
10653.59 In reply to 10653.51
Thank you for your time and help :-)
Here is a new question:
I noticed that Nodeeditor doesn't work in V5. I have it installed in V4 is there away to have it active in V5 as well?
Best,
Psygorn
10653.60 In reply to 10653.59
Hi Psygorn,
The Nodeeditor works the same in V5 as it does in V4.
How do you have it installed in V4, do you maybe have it copied into the V4 program files install directory instead of in app data?
How are you launching it in V4, can you show me the shortcut key that you have set up for it?
10653.61 In reply to 10653.60
Nodeeditor located here: "C:\...\AppData\Roaming\Moi" that's why I expected it to work with V5 as well.
The short key I use for it in V4 is: Alt+N
-Psygorn
10653.62 In reply to 10653.61
Hi Psygorn,
Yes, if it's being used from there it should work in both v4 and v5 as well.
Can you also post the text you have for the "command" part of the shortcut key?
10653.63 In reply to 10653.62
A new issue appeared! (It has nothing to do with Nodeeditor)
Open the attached file in V5, select all red curves press Ctrl and while have it pressed try to move them (basic copying procedure)! V5 copies only few lines not all of the selected lines! (V4 is able to open this file and there everything works fine)
Here is the script:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
I changed it to : script: if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 5 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
and Now it works :) thank you for the hint.
Edit: or maybe I shouldn't change it that way?
Please help me with other issue.
-Psygorn
10653.64 In reply to 10653.63
Hi Psygorn, for the node editor since you probably don't use version 3 anymore you can remove the version specific stuff in there and just put this:
script: moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
That will then work in v4, v5, and v6+
Your new one above will break again when major version number becomes 6 in the future.
For your red curves, that's definitely a bug in v5 where Ctrl + drag is not copying edge curves like it should be. Some of the selection changes relating to groups must have broken that.
For the time being use Transform > Copy to copy edge curves instead of Ctrl+drag . I'll work on fixing the bug for the next beta release, thank you for reporting it!
Thanks, - Michael
10653.65 In reply to 10653.64
Thank you for your help & time. :-)
-Psygorn
10653.66 In reply to 10653.34
This folder structure you mention would be really useful — I actually need it far more than I need the existing group, which is more like a compound part object than a group of independent objects.
10653.67
With the new groups, it would be nice to be able to make the side panel a bit wider. It could be done in terms of how many columns of buttons you have — I'd be happy to go to five or even six columns.
10653.68
Also, in the dark theme, the selection rectangle and construction lines are pretty hard to see if you also have a darkish background color. It would be nice to have them tweakable without a full theme swap.
10653.69 In reply to 10653.67
Hi Cuboctahedron,
If you have Options > General > Scene browser position = "Adjacent" mode set so the scene browser is in its own pane you can make it as wide as you need by dragging its edge.
10653.70 In reply to 10653.68
Hi Cuboctahedron,
Can you please post a screenshot of what you're seeing?
When you have a dark background, the construction lines should display as alternating dark and white to make them easier to see. That should change from the regular light mode display where they are drawn in a dash pattern of color / transparent / color / transparent etc...
It's generally best not to have a really pitch black viewport background because then files that you open with black lines in them will be very difficult to see.
10653.71 In reply to 10653.69
Yes. This is great, but it still wastes a lot of screen. I guess as an alternative, being able to pin both the construct and transform groups open at the same time would be nice, but that's probably just a re-skinning at that point :-)
EDITED: 17 Apr 2022 by CUBOCTAHEDRON
Size: 513.5 KB, Downloaded: 80 times, Dimensions: 586x2157px
10653.72 In reply to 10653.70
With this color scheme, sometimes I get a nice bold black selection rectangle, and sometimes I get this.
Size: 335.7 KB, Downloaded: 90 times, Dimensions: 523x445px
10653.73 In reply to 10653.71
Hi Cuboctahedron,
When you're not actively using the browser pane you can hide it using the "Browser" button at the bottom.
There is a startup script you can put in which will ungroup the palettes:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
And a couple of variations:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9953.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.487
10653.74 In reply to 10653.72
Hi Cuboctahedron,
re :
Is it that you're getting the bold one when you start on the left and drag towards the
right and the anemic one when starting on the right and dragging towards the left?
The left to right one displays with solid lines and will capture only things completely
contained inside the window.
The right to left one ("crossing window") displays with dashed lines and will target
anything that touches the rectangle, not just completely contained within.
The dashed line one is doing a color / transparent / color / transparent type dash
pattern. I'll see about switching it to a dark / white / dark / white pattern instead
like construction lines have now in the dark theme.
Thanks for showing the problem.
10653.75
I hope you are doing well, I have got a couple of quick questions for you.
Could we have an ability to extract edges as individual curves when we press Join on them? ( I know Join does that for polyline edges but it seems it doesn't do it with single edges or for example bases of a Cylinder) ( see the green line in the attached file)
Also Could we have an ability to quickly extract intersection line of two colliding surfaces? (see the red line in the attached file)
10653.76 In reply to 10653.75
Hi Psygorn,
Join is focused on combining multiple objects together and so it ignores a single
object input.
You can extract edges as individual curves by selecting them and using
Ctrl+C/Ctrl+V copy/paste on them. That will work with any kind of edge selection.
You can do that now by selecting your 2 surfaces and then run the Construct > Curve >
isect command. That command generates curves or points at the intersections
between objects.
Show messages:  1-16  17-36  37-56  57-76  77-84
