V5 Beta test
 1-17  18-37  38-57  58-77  78-84
10653.38
Hello Michael,
I installed Moi V5 just now and when I wanted to open it I ran into some errors.
in the above image you can just see 4 of them but they are more!
After clicking ok on all of these error messages Moi V5 opens!
(needless to say I changed some features in Moi V4 but I did not think they could affect V5!)
Edit: When choose the dark theme those error messages appear again! but in dark theme windows.
EDITED: 12 Apr 2022 by DRILLBIT
10653.39 In reply to 10653.38
Hi Psygorn,
It looks like those are all coming from startup scripts you have added to the
MoI appdata startup folder.
The problem is that those scripts are depending on modifications that you've made
to the MoI v4 browser pane.
You would get the same errors if you were to try and run a default v4 on your machine
that didn't have your modified browser pane.
There are various ways you can fix this up. Probably the best is since your startup scripts
depend on a specific customized version you should probably set them up to run only with
that version instead of having them in the common appdata folder where all versions will
find them.
To do that make a startup folder inside the install folder for v4 so you have
C:\Program Files\MoI 4.0\startup and move your startup scripts from their current
location in the shared appdata folder (%appdata%\Moi\startup) to the install-specific one.
After you have done that then those startup scripts should only run with that customized
v4 install and other installs of MoI will not see them.
The other options you could do would be to apply the same browser pane mod to the v5
beta so the scripts would be able to find what they are expecting there too, or another option
yet would be to modify the scripts so that they tolerate errors silently which you can do by
putting a try / catch block around the script code like this:
try {
    >>> code goes here <<<
} catch(e) {}
Things that you add to the central appdata folder will be seen by new versions automatically.
That's so you can do things like install plug-ins there and not need to copy them to individual
install folders with new program releases.
When you switch themes the UI is reloaded and startup scripts are run again since many startup
scripts involve UI mods.
10653.40 In reply to 10653.39
Thank you for your help, however, I have got a few questions for you:
Is it possible to have Moi discovers startup settings automatically?
By doing above mentioned solution Moi V5 beta would have the same UI settings as Moi V4? Do I have to do things manually In order to apply the same browser pane mode to the V5 beta? Is there a way I can have it done automatically? And basically, tell me how to do it!
-Psygorn
10653.41 In reply to 10653.40
Hi Psygorn,
Sorry I don't understand the question. What do you mean by "startup settings" ?
> > to the v5 beta so the scripts would be able to find what they are expecting there too
I'm not sure what you mean by "UI settings" in this context. What it would do would be to
make the MoI v5 beta have the same structural content as your customized v4.
The reason why you are getting script errors is because your scripts are looking for an HTML
element with id="CommandBarCustomUI" inside of the file BrowserPane.htm .
The regular MoI install does not have any element with that id in BrowserPane.htm , it has
it in CommandBar.htm .
So for those scripts to be working in v4 you must have modified your v4 BrowserPane.htm
file to have that element in it.
If you modify your V5's BrowserPane.htm to have the same thing that you added to the v4 one
then that would solve the problem.
It could be possible to change your scripts so that they insert at the end of the <body> of
BrowserPane.htm or something like that instead.
If you can post your startup scripts and the modified BrowserPane.htm file you have made
for v4 then I'll be able to tell you how to do that.
10653.42 In reply to 10653.41
Thank you for your time and your support. :)
Sure! I would prefer to leave things in your hands in order to prevent myself from messing up with the codes.
I have attached Scripts.js as well as Scripts Full.js
If you need something else please do tell me.
Edit: I have renamed BrowserPane.htm files for better indication
10653.43 In reply to 10653.42
Hi Psygorn, here are updated versions of those scripts,
With those in place does it work ok both in v4 and v5 now?
10653.44
hi,
one question. is it possible to deselect a group in the view panel? @moment if i select 2 groups and want to deselect one of them, i end up with one selected object of the to-deselected group.
best, marco
10653.45 In reply to 10653.44
Hi marco,
When you do a second click on a group, it will "drill in" to select children of the group, similar to how a second click on a solid selects edge or face sub-objects of the solid.
With a solid if you use Ctrl+click on a selected solid, it will deselect it without doing any drill-in. I should be able to make the same behavior with groups, but that's not working at the moment.
For now you can deselect it though by doing ctrl+click on your one selected sub-object, or if you continue to drill in when you can't drill in anymore the last click will deselect (without ctrl).
10653.46 In reply to 10653.43
I replaced those scripts with updated ones at C:\...\AppData\Roaming\Moi\startup
I still see error messages with V5. ( not with V4)
A question: Shouldn't I replace BrowserPane.htm of V5 with BrowserPane.htm of V4?
-Psygorn
10653.47 In reply to 10653.46
Hi Psygorn,
Are there any additional scripts in your startup folder aside from the 2 you posted?
It could work but it can also be problematic to get a kind of frankenstein collection of old and new versions all combined together. You can run into things like missing new stuff that has been added in to V5.
If I can update the scripts you are using then you won't need to do that.
10653.48 In reply to 10653.47
Yes, there are at least 13 other .js files there! I thought you only need ones with "script" on their names! sorry, my bad!
The whole old startup folder is attached. (it's a zip file)
-Psygorn
10653.49 In reply to 10653.48
Hi Psygorn, here you go, use all these updated versions instead and does that work the same in v4 and v5 for you after that?
10653.50 In reply to 10653.49
Yes, It works fine :-)
Thanks for your time and help!
10653.51 In reply to 10653.50
You're welcome Psygorn, I'm glad it is working now!
10653.52 In reply to 10653.51
Hi, Michael, on mac, after intalling v5, the mouse wheel don't zoom but go up or down in 3d view, and all other views. What is the situation ? Normal behavior on v4.
10653.53 In reply to 10653.52
Hi moujiik,
What kind of mouse do you have, is it Apple's "Magic Mouse" or a different one?
In v5 the default behavior of Magic Mouse "scrolling" (1 finger swipe) in MoI is to pan instead of zoom.
That's to fix a bug in trackpad handling.
You should be able to revert to V4 behavior by setting this value in moi.ini :
[MultiTouch]
UseTrackpadScrollAsMouseWheel=y
Or also in v5 if you hold down the Alt key when doing the wheel motion it should work as a zoom instead of a pan.
So the reason for this is kind of a convoluted story. The way a trackpad works is the 2 finger swipe gesture normally does a panning type action and pinching is used for zooming. The Magic Mouse happens to send the exact same event for it's "scroll" as the trackpad 2 finger swipe.
In MoI v4 I tried to detect if the scroll event was coming from a trackpad or a magic mouse to do panning for the trackpad and zooming for the magic mouse.
Unfortunately the detection didn't work in certain situations, causing a bug where 2 finger swipe on the trackpad started to do zoom (like it was a magic mouse) instead of pan, as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10277.1
As best as I can tell there is not any totally reliable method for distinguishing a scroll event as coming from a magic mouse (with one finger swipe) or a trackpad with 2 finger swipe.
So it seems that Apple really wants the Magic Mouse to work like a trackpad so that's what MoI is doing now with v5. I've given up on trying to automatically detect which type of device was used to generate the event.
10653.54
When I select the object and then change the color (style) to default, the object deletes itself...
Bug?
10653.55 In reply to 10653.54
Hi Death,
> Bug?
It's actually not deleting itself, it's hiding it because all the other objects assigned to Style = Default were hidden.
I noticed recently that that behavior got accidentally broken at some point quite a while ago and I restored it in v5.
The concept is if all the objects currently assigned to the style are hidden or locked it makes the object you are assigning there to assume the same state.
If you hold down shift+ctrl when clicking the style swatch it won't change the object state.
Maybe since it was broken for a long time and nobody noticed it would be better to not do that. It's meant to make styles behave a little more similar to layers.
EDITED: 13 Apr 2022 by MICHAEL GIBSON
10653.56 In reply to 10653.55
IDK, but I would prefer it NOT to happen, it is a bug.
If you could fix it, that would be great.
Until you explained the bug, I was at a loss...
I did a few other objects and they all "disappeared", so I naturally assumed it to be a bug in the beta release..
Almost reinstalled version 4 to get past it, but thought to ask you first.
Thanx.
10653.57 In reply to 10653.53
Hi Michael, yes it's a magic mouse, i'll check your solution at work this morning.
Thank you.
Moujiik
Show messages:  1-17  18-37  38-57  58-77  78-84
