V5 Beta test
 1-11  12-31  32-51  52-71  72-84
10653.32 In reply to 10653.25
Hi Viewbyte,
re: copy sub object out of a group
> Not sure if this is a bug, or if I'm just missing the logic here:
Looks like a bug, it looks like copying sub objects out of the group is messed up right now. I'm pretty sure I had it working ok at one point but it probably got messed up when tuning groups processing in some other command.
I'll dig in to it and see where it got messed up.
Thanks, - Michael
10653.33 In reply to 10653.30
I wasn't sure that this was the intended behavior, but yes, that makes sense and will work well either way.
Maybe a button: "Exclude locked objects" would be fine to select the group and NOT move the locked ones. That way one doesn't have to select all the non locked ones manually.
10653.34 In reply to 10653.33
Hi Death, I guess the question I have is if you want the locked objects to not move with the rest of the group, then why is it that you want them to be in the same group as the other objects?
If they are not meant to move together then they probably shouldn't be in the same group object since moving things together is one of the main things that groups are focused on doing.
There is probably room for an additional type of hierarchical organizing method like "folders" that would be a sort of looser connection between the objects and not make them behave as a single compound object like groups are.
You can get part of that type of behavior currently by the pre-v5 "grouping" mechanism of having a set of objects with the same name.
10653.35 In reply to 10653.34
Well, sometimes you have group and you want to move everything in it, BUT one or more objects, they might have to stay stationary.
Imagine a hinged joint, where you want to move the group that includes it, around the hinge, but not the hinge, or it's hinge pieces...
There are many more reasons to have a group's objects move without the locked objects in it.
My suggestion would make things easier, that's all.
10653.36 In reply to 10653.35
Hi Death,
You should probably set this up as having sub groups - have the pieces you want
to move in a sub group that's a child of the main group. When you want to move them and
leave other pieces stationary select the sub group and not the whole parent group.
Locking has to do with selection, not for marking things as stationary.
10653.37 In reply to 10653.36
That would work.
I am thinking of a messy layout of groups and subgroups though.
A robotic hand with joints and wrist on an arm on a body etc. etc.
I'd rather lock on an element and rotate for ex. the rest about it without having to select a ton of objects to do it.
Just my 5 cents worth. Either way it is a great thing to have grouping, very exiting. All the latest additions (like dimension, themes etc.) made me love Moi even more.
Keep up the good work, can't wait to see what other goodies you are going to come up with. (better fillets maybe?)
Thanx!
10653.38
Hello Michael,
I installed Moi V5 just now and when I wanted to open it I ran into some errors.
in the above image you can just see 4 of them but they are more!
After clicking ok on all of these error messages Moi V5 opens!
(needless to say I changed some features in Moi V4 but I did not think they could affect V5!)
Edit: When choose the dark theme those error messages appear again! but in dark theme windows.
EDITED: 12 Apr 2022 by DRILLBIT
10653.39 In reply to 10653.38
Hi Psygorn,
It looks like those are all coming from startup scripts you have added to the
MoI appdata startup folder.
The problem is that those scripts are depending on modifications that you've made
to the MoI v4 browser pane.
You would get the same errors if you were to try and run a default v4 on your machine
that didn't have your modified browser pane.
There are various ways you can fix this up. Probably the best is since your startup scripts
depend on a specific customized version you should probably set them up to run only with
that version instead of having them in the common appdata folder where all versions will
find them.
To do that make a startup folder inside the install folder for v4 so you have
C:\Program Files\MoI 4.0\startup and move your startup scripts from their current
location in the shared appdata folder (%appdata%\Moi\startup) to the install-specific one.
After you have done that then those startup scripts should only run with that customized
v4 install and other installs of MoI will not see them.
The other options you could do would be to apply the same browser pane mod to the v5
beta so the scripts would be able to find what they are expecting there too, or another option
yet would be to modify the scripts so that they tolerate errors silently which you can do by
putting a try / catch block around the script code like this:
try {
    >>> code goes here <<<
} catch(e) {}
Things that you add to the central appdata folder will be seen by new versions automatically.
That's so you can do things like install plug-ins there and not need to copy them to individual
install folders with new program releases.
When you switch themes the UI is reloaded and startup scripts are run again since many startup
scripts involve UI mods.
10653.40 In reply to 10653.39
Thank you for your help, however, I have got a few questions for you:
Is it possible to have Moi discovers startup settings automatically?
By doing above mentioned solution Moi V5 beta would have the same UI settings as Moi V4? Do I have to do things manually In order to apply the same browser pane mode to the V5 beta? Is there a way I can have it done automatically? And basically, tell me how to do it!
-Psygorn
10653.41 In reply to 10653.40
Hi Psygorn,
Sorry I don't understand the question. What do you mean by "startup settings" ?
> > to the v5 beta so the scripts would be able to find what they are expecting there too
I'm not sure what you mean by "UI settings" in this context. What it would do would be to
make the MoI v5 beta have the same structural content as your customized v4.
The reason why you are getting script errors is because your scripts are looking for an HTML
element with id="CommandBarCustomUI" inside of the file BrowserPane.htm .
The regular MoI install does not have any element with that id in BrowserPane.htm , it has
it in CommandBar.htm .
So for those scripts to be working in v4 you must have modified your v4 BrowserPane.htm
file to have that element in it.
If you modify your V5's BrowserPane.htm to have the same thing that you added to the v4 one
then that would solve the problem.
It could be possible to change your scripts so that they insert at the end of the <body> of
BrowserPane.htm or something like that instead.
If you can post your startup scripts and the modified BrowserPane.htm file you have made
for v4 then I'll be able to tell you how to do that.
10653.42 In reply to 10653.41
Thank you for your time and your support. :)
Sure! I would prefer to leave things in your hands in order to prevent myself from messing up with the codes.
I have attached Scripts.js as well as Scripts Full.js
If you need something else please do tell me.
Edit: I have renamed BrowserPane.htm files for better indication
10653.43 In reply to 10653.42
Hi Psygorn, here are updated versions of those scripts,
With those in place does it work ok both in v4 and v5 now?
10653.44
hi,
one question. is it possible to deselect a group in the view panel? @moment if i select 2 groups and want to deselect one of them, i end up with one selected object of the to-deselected group.
best, marco
10653.45 In reply to 10653.44
Hi marco,
When you do a second click on a group, it will "drill in" to select children of the group, similar to how a second click on a solid selects edge or face sub-objects of the solid.
With a solid if you use Ctrl+click on a selected solid, it will deselect it without doing any drill-in. I should be able to make the same behavior with groups, but that's not working at the moment.
For now you can deselect it though by doing ctrl+click on your one selected sub-object, or if you continue to drill in when you can't drill in anymore the last click will deselect (without ctrl).
10653.46 In reply to 10653.43
I replaced those scripts with updated ones at C:\...\AppData\Roaming\Moi\startup
I still see error messages with V5. ( not with V4)
A question: Shouldn't I replace BrowserPane.htm of V5 with BrowserPane.htm of V4?
-Psygorn
10653.47 In reply to 10653.46
Hi Psygorn,
Are there any additional scripts in your startup folder aside from the 2 you posted?
It could work but it can also be problematic to get a kind of frankenstein collection of old and new versions all combined together. You can run into things like missing new stuff that has been added in to V5.
If I can update the scripts you are using then you won't need to do that.
10653.48 In reply to 10653.47
Yes, there are at least 13 other .js files there! I thought you only need ones with "script" on their names! sorry, my bad!
The whole old startup folder is attached. (it's a zip file)
-Psygorn
10653.49 In reply to 10653.48
Hi Psygorn, here you go, use all these updated versions instead and does that work the same in v4 and v5 for you after that?
10653.50 In reply to 10653.49
Yes, It works fine :-)
Thanks for your time and help!
10653.51 In reply to 10653.50
You're welcome Psygorn, I'm glad it is working now!
Show messages:  1-11  12-31  32-51  52-71  72-84
