V5 Beta test
 1-10  11-30  31-50  51-70  71-84
10653.11
On V5 Beta:
This DXF file is imported.
The 'ReconstructCurve' script is run and the V5 beta program closes without warning.
It works okay on V4.
Wayne
The following scripts do not work in v5. v5 closes.
RadialPattern
Gear
Gear2
SpurGearProfile
Cloth
BlendCap (For a simple extruded circle (cylinder).
(A common theme is the user having to select something...)
10653.13 In reply to 10653.11
Hi Wayne,
Thanks for reporting this - it's an object refcount bug in some new group processing code in the array curve factory. It doesn't get triggered with the regular use of array curve, the circumstances to trigger it are when a script is using it, when there are "loose" objects used in intermediate stages of geometry processing that are not in the geometry database.
I've got it fixed up for the next release. I'll collect up a few more bugs to fix before putting out a new release.
10653.14 In reply to 10653.12
> RadialPattern
> Gear
> Gear2
> SpurGearProfile
> Cloth
It's probably from the same array bug that's messing up ReconstructCurve too.
Can you please .zip up these scripts and e-mail them to me at moi@moi3d.com ? It would be good if I could make sure I'm using the exact same versions to test.
Thanks! - Michael
10653.15 In reply to 10653.14
Zip of 9 files sent, including _ArcToCircle, _CCC, _cMorph, _FatLines.
A bunch of other scripts Do work properly in V5Beta Apr-9-2022
10653.16
groups gone mental..
sorry, i dunno how to embed a video. img is just a screenshot..
https://screencast-o-matic.com/watch/c3fX1mVqdaT
10653.17 In reply to 10653.16
Hi Marco, thanks for the video link, I can repeat that over here.
It looks something like the group structure is getting into some kind of circular self referencing state.
The fix will be that it should just do nothing when you click on the same item where the selected objects are already at.
10653.18 In reply to 10653.1
Hi Phiro,
re: Ctrl+A / select all not highlighting group - I just rolled out a new Apr-10 version and I think this should be fixed now. Please let me know if it works ok for you now.
Thanks, - Michael
10653.19 In reply to 10653.11
@ Wayne,
I just rolled out a new Apr-10 version and I think this should be fixed now, can you please let me know if it works ok now?
Thanks, - Michael
10653.20 In reply to 10653.12
@ Brian,
Should hopefully be fixed in new Apr-10 version I just put up.
Thanks, - Michael
10653.21 In reply to 10653.16
@Marco,
Should be fixed in new Apr-10 version I just put up.
The bug was when trying to assign a group to be a child of itself. That case should just do nothing now.
Thanks, - Michael
10653.22 In reply to 10653.19
The V5 Beta Apr-10-2022 fixed the issue with the 'ReconstructCurve' script error.
Thank you,
Wayne
10653.23 In reply to 10653.20
The 8 scripts are working in Apr-10 beta.
(Cloth was 2014 version, and did not work in V4 either)
Max's Cloth 2017 appears to be working in V4 and V5, but sphere drape did not work in either V4 or new V5. Maybe I did not set up correctly...
Edit: Drape does work, with proper usage. Thankyou Pilou.
EDITED: 11 Apr 2022 by BEMFARMER
10653.24 In reply to 10653.23
Cloth works fine!V3, V4, V5 ;)
Just select for example a line(s) of points then click the Sphere(s) then Done, Done...!
Don't take "small" spheres!
Take Wind 90,90,0 Physics 5,1,20,10 Constraints 14,1,1,8
Here with the V5 beta
EDITED: 11 Apr 2022 by PILOU
10653.25
Not sure if this is a bug, or if I'm just missing the logic here:
Create 3 boxes - boxes 1, 2, and 3.
Select them and Group.
Click on box 1 to select that individual box
Drag copy or use the copy tool to create a copy of box 1 = box 4.
Deselect
Selecting in the Objects browser now shows:
The first group I created - originally containing boxes 1, 2 & 3 - now contain boxes 2, 3 & 4.
A new group containing just box 3.
10653.26 In reply to 10653.24
Thank you Pilou.
10653.27 In reply to 10653.10
My settings (Options > General > Unit system)
10653.28 In reply to 10653.18
Hi Michael
Fixed !
Perfect !
10653.29 In reply to 10653.20
April 10th release:
Groups and locked objects don't play well with each other:
Make some objects, group 2 of them, then select one of the group objects and lock it. Deselect all, select the one in the group that wasn't locked, click and drag. The other locked group member moves with it....
10653.30 In reply to 10653.29
Hi Death,
This current behavior is correct. In your step where you click and drag, it's the group that is being selected and dragged and if the group is selected then that means that the entire group object will be dragged.
That's one of the main things that Groups is for, to make a set of objects all transform together as one unit.
If you want to move only the one object you'll need to do a "drill in" selection clicking on it so just that sub-object is selected and not the entire group.
It's similar behavior as with BRep sub objects. In v4 if you draw a box and select an edge of the box and lock it, if you then drag the box the locked edge is not left behind, it goes along with the box.
Locking a sub-object prevents it from being targeted individually for selection, it does not stop it from being transformed if its parent object is being transformed.
Show messages:  1-10  11-30  31-50  51-70  71-84
