V5 beta Apr-10-2022 available now
 1-12  …  53-72  73-92  93-96
10652.93 In reply to 10652.92
Thank you Michael.
So I did some experiments.
When I take off my glasses, the effect goes away.
When I look through the reader portion of the glasses, the effect tends to go away.
And maybe there is some of that mach banding going on, for that white effect.
So I'll blame most of the effect on the age of this user :-)
And I'll keep using the dark red for y-axis, rather than red.
EDITED: 22 May 2022 by BEMFARMER
10652.94 In reply to 10652.1
Looking forward to trying this new beta release!
EDITED: 22 May 2022 by VEGASGUITARS
10652.95
Update mesh export vertex normal combining. Change vertex normal combining to use tolerance of 0.5 degrees instead of 3.0 degrees. It can also be changed now in moi.ini .
[Mesh Export]
UnifyVertexNormalsAngleToleranceDegrees=0.5
Hello. I have been using Moi3D to convert SolidWorks>STEP>Moi export OBJ and when you get into Blender you have to use the merge command to merge vertices which are never combined. Does this remove the need to do this? In Blender merge is done by distance, so I am not sure if angle changing will fix it.
10652.96 In reply to 10652.95
Hi Pj,
Are you using the setting "Weld vertices along edges" in the Meshing options dialog when you
do the export out from MoI?
No, the vertex normal combining makes 2 normals that are very close to each other become
exactly equal. It doesn't have to do with merging vertices. The "Weld vertices along edges" shown
above is what enables merging vertices.
Show messages:  1-12  …  33-52  53-72  73-92  93-96
