V5 beta Apr-10-2022 available now
 1-16  17-36  37-56  57-76  77-96
10652.37 In reply to 10652.35
Hi charles,
> I've downloaded the beta and have attempted to create a custom theme, however there's
> two things I can't seem to change. I've attached a screenshot of the areas I mean.
The first one is in the theme editor under Side pane > "Command set background color".
For the second one, there isn't anything set up for scroll bars in the dynamic theme editor but you can set it in the theme's moi.css file using this (last scrollbar property set in the regular dark theme moi.css):
::-webkit-scrollbar-track-piece {
background-color:#777;
10652.38
Thank you for replying so quickly.
That's awesome, thank you so much.
Have a wonderful Easter.
cheers
charles
10652.39
Maybe I've not had enough coffee, but I'm puzzled as to why the beta is not liking my Extras startup script (based upon Max's Scripts menu)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10353.1
First thought was some of the Mac filesystem changes (I'm on an M1 MBP) but it doesn't even get that far. Seems like the .js portion loads and creates the Extras icon in the menu bar, but the .htm portion never gets to starting the embedded <script>.
Something changed in CommandBarCustomUI maybe?
moi.ui.commandBar.CommandBarCustomUI.insertAdjacentHTML( "beforeEnd",
'<moi:Spacer/><moi:Spacer/><moi:CommandMenuButton icon="'+icon+'" menu="'+menu+'">'+title+'</moi:CommandMenuButton>');
--Larry
10652.40 In reply to 10652.39
I seek to use MoI with minimal changes, so my customizations are only done in the startup folder. In this case I have disabled the other startup scripts to see if they are part of the puzzle but the behavior is the same.
Reading the V5 Beta test thread I found your conversation with Psygorn in which you fixed his startup scripts. Those changes appeared to be applicable to my problem so I applied the same changes to my Extras.js and the result is strange in that the Extras icon no longer shows in the command bar area to the right of the snaps, but is instead showing up in the browser area beneath the objects, types, styles panels. This is behavior consistent with both MoI V4 and MoI v5 beta Apr-10-2022. My original Extras-001.zip is referenced in the prior message.
Additionally, although the icon has moved, under V5 beta the behavior remains the same: instead of creating a flyout menu with the list of commands as is normal with V4, V5 beta just creates a small empty box above the icon where the much larger flyout would normally appear. It seems that the embedded script is simply not run and there are no error messages with either my original Extras or the one which incorporates the changes shared with Psygorn. Puzzling...
--Larry
10652.41 In reply to 10652.39
Hi Larry, your Extras.htm and Extras.js are working ok on Windows but not on Mac.
I'll dig into it to see what's going wrong over there.
The strange result is how Psygorn wants the UI to be set up, that's what his modified
version does.
10652.42 In reply to 10652.39
Hi Larry, I think it's some kind of bug in handling the file encoding of your Extras.htm file.
Something like a unicode character for the apostrophe in the comment.
If you use the version attached here does it work ok for you then?
I'll investigate a fix for it.
10652.43 In reply to 10652.42
Oh good grief, I would never have guessed that (single quote vs apostrophe) to have been the problem. Yep, works perfectly once again, many thanks!
--Larry
10652.44 In reply to 10652.43
You're welcome Larry I'm glad it's running ok for you now.
So yes it was because of that one apostrophe was a unicode character. With the new theme support there were some changes to how .htm files were read and the Qt text stream loader doesn't behave exactly the same as the WebKit text encoding detector.
I'll see about using the WebKit text file loader again to get the same behavior as v4.
10652.45
Hi Michael Gibson
My license key is not working when trying do download V5 beta Apr-10-2022. Can you help me figure out the problem. I purchased v3 and upgraded to v4, so I don't understand why my license key is not working?
Ogar
10652.46 In reply to 10652.45
My 3 licenses are in my MoI AppData folder, v2, v3, and v4.
10652.47 In reply to 10652.45
Hi Ogar, please e-mail the license key to me at moi@moi3d.com so I can investigate what might be going wrong.
Thanks, - Michael
10652.48 In reply to 10652.45
Hi Ogar,
Looking at the server web logs, it looks like the problem is you're putting the v3 key instead of your v4 key.
The v3 key starts with VER3- , the v4 one starts with VER4- that's the one you need.
You can find your v4 key in MoI v4 under Help > About MoI > "License keys" or also you can put in your e-mail address at https://moi3d.com/reinstall.htm and it will look up your license key and e-mail it to you.
10652.49
Hi Michael.
If I buy the v4 now(as 2022-4-27), do I pay for the v5 upgrade or it will be a free upgrade?
Sorry if this has been asked.
Thanks!
10652.50 In reply to 10652.49
Hi r0ss0,
It would be a paid upgrade. There will be a "grace period" where if you purchase v4 within a couple of months of the v5 release you will get a free upgrade to v5. But the v5 beta period has only just recently started, the full release is quite a ways off yet definitely more than a couple of months.
So a v4 purchase right now would not be in the grace period time for getting a free v5 upgrade.
10652.51 In reply to 10652.1
> Update Mac trackpad/Magic Mouse handling.
Two thumbs up on these changes! I use MOI on a MacBook Pro (without a mouse) & the V4 trackpad handling was inconsistent as you know. I haven't spent a lot of time with the beta but am noting with pleasure that I can use 2-finger drags to get panning reliably...used to be that sometimes it would get stuck and zoom instead. Now I have to "teach" myself to use it as intended! ;-}
--Larry
10652.52
I'm currently testing Plasticity and some of the features are very interesting. More specifically the ability to do live Chamfering and Filleting and even more importantly the ability to rotate faces (there are still issues with rotating faces, but it looks promising).
Are these features something that you are considering at the moment for the next version of MoI? These features are extremely powerful and save an enormous amount of time when modeling.
Thank you.
10652.53 In reply to 10652.52
Hi RD,
A few months ago I was planning on that but unfortunately the circumstances have changed and that's no longer the case.
Plasticity is doing them by using a geometry library called C3D. I had also wanted to use C3D to do the same things inside of MoI but it's become unfeasible to do that because C3D is the product of a Russian company and the Russia/Ukraine war has made it untenable to license it for use in MoI.
I might attempt to do my own implementation of direct face editing (the rotate face part) at some point here but I don't know when. There is a lot of work involved and so it's not very likely for the next version.
What is the situation with face rotation that is causing trouble in Plasticity, do you have an example of that?
10652.54 In reply to 10652.53
Have you considered using Parasolid instead of C3D? It looks like it's fairly expensive and based on what the creator of Plasticity has said (he's also exploring Parasolid because of the same reasons that you have just mentioned), it could increase the price of Plasticity significantly. But apparently this third party library has even some support to move and scale edges, which is very interesting.
About the example of issues with face rotation, I found some issues when filleting after doing the rotation operation, but I did not save the file unfortunately. I will let you know if I can re-create it and will post an example.
Thank you.
10652.55 In reply to 10652.54
Hi RD, yes I've looked into using Parasolid before but it's not a great fit for MoI.
First because it's quite expensive and licensing it puts various restrictions on how you can price and deliver the product using it. In general it's very corporate/"Big Enterprise" oriented.
But also I found it to be kind of finicky in the type of geometry it accepts, especially with closed surfaces. It represents trimming boundaries on closed surfaces in a somewhat different way than MoI's current geometry library does and that makes for some problems in transferring model data between them.
It's a lot of work to switch everything in MoI over to a different library, the main way that I would want to use a new library would be to use it initially in just a couple of key spots like filleting, shelling, and face transforms and translate model data back and forth between the kernels. When the trim boundary mechanisms don't match up too well that becomes difficult to do with 100% reliability.
One of the things that was particularly good with C3D is that it represented trim boundaries similar to how MoI currently does where a trim boundary 3D edge curve maps directly to a surface uv parameter space curve and does not cross over the seam of a closed surface like Parasolid's method.
Maybe at some point I will re-evaluate it but not anytime soon. Certainly not for the next version. It's more likely that I would do some experimental work on face transforms myself first before doing that.
I'm fairly lucky that I didn't end up investing a whole lot of time with C3D, I had just started an in depth evaluation of it a couple of weeks before the war started.
10652.56 In reply to 10652.55
"First because it's quite expensive and licensing it puts various restrictions on how you can price and deliver the product using it. In general it's very corporate/"Big Enterprise" oriented."
That's the impression that I get from this as well.
"Maybe at some point I will re-evaluate it but not anytime soon. Certainly not for the next version. It's more likely that I would do some experimental work on face transforms myself first before doing that."
I hope that you succeed doing so, that would be a very valuable addition to MoI3d imo.
Here's an example of what I have mentioned previously when testing Plasticity and the face rotation function.
With a simple test cube, I've rotated one of the face, and then performed a Chamfer operation (not fillet actually, I could not reproduce it using fillet, but I'm certain that I have seen some strange results with the fillet operation as well). You can see the unexpected result in the fourth image. The last image is the same Chamfer operation performed on one of the cube faces, without any rotation. Hope this helps.
Thank you.
Size: 741.5 KB, Downloaded: 96 times, Dimensions: 2460x2449px
Show messages:  1-16  17-36  37-56  57-76  77-96
