I seek to use MoI with minimal changes, so my customizations are only done in the startup folder. In this case I have disabled the other startup scripts to see if they are part of the puzzle but the behavior is the same.
Reading the V5 Beta test thread I found your conversation with Psygorn in which you fixed his startup scripts. Those changes appeared to be applicable to my problem so I applied the same changes to my Extras.js and the result is strange in that the Extras icon no longer shows in the command bar area to the right of the snaps, but is instead showing up in the browser area beneath the objects, types, styles panels. This is behavior consistent with both MoI V4 and MoI v5 beta Apr-10-2022. My original Extras-001.zip is referenced in the prior message.
Additionally, although the icon has moved, under V5 beta the behavior remains the same: instead of creating a flyout menu with the list of commands as is normal with V4, V5 beta just creates a small empty box above the icon where the much larger flyout would normally appear. It seems that the embedded script is simply not run and there are no error messages with either my original Extras or the one which incorporates the changes shared with Psygorn. Puzzling...
--Larry
