HELP WITH NODE - OBJECT TWIST CONTROLLED BY INPUT CURVE
All  1-7  8-18
10649.8 In reply to 10649.6
Rather than scanning, the wavy curve could be Flowed to the cylinder.
10649.9
Thanks all for varying inputs but James hit the nail right on the head - exactly what I was conceptualising the control would be to have as Brian mentioned a propeller prop but with varying sections of tight and loose twists to make a complex helicoid as mentioned.
Would be great to have a play with the NODE let me know if you need anything from my end.
The wealth of knowledge in this forum is deep and drawing from various pools making MOI one of the sharpest tools in the kit.
Amazing result.
10649.10 In reply to 10649.9
Alex,
To make it easier on myself I modified your 3DM, placing items on ground plane because NE generally defaults to Top view. Also I increase the size of your waveform to have a height of 360 units (180 either side of axis). This step was not necessary, it could have recalculated from your original, but doing so simplified the approach building the node circuit.
Please find new 3DM & NOD files attached
EDITED: 8 Apr 2022 by JFH
10649.11 In reply to 10649.10
James' node works!
EDITED: 8 Apr 2022 by BEMFARMER
Message 10649.12 deleted 9 Apr 2022 by JFH
10649.13 In reply to 10649.12
Curiously works not for me! :(
I have updated the last NodeEditor from here
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
The only "red one" is this... and a free Node "Output" floating in the screen Node editor without link...(but it's not the final one)
EDITED: 8 Apr 2022 by PILOU
10649.14 In reply to 10649.13
You could use curves/rectangle followed by construct2/planar, or
alternatively add these nodes to nodes/extension folder:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1710
I want to overhaul the node libraries but it will be a major project
for which I don't have time for in foreseeable future.
EDITED: 9 Apr 2022 by JFH
10649.15 In reply to 10649.14
Perfect!
(added the "Shapes" files .js! )
EDITED: 9 Apr 2022 by PILOU
10649.16
James - Wow one small Node request so many tangles true mastery in the NODE world works great had a quick play with more complex input shape will play some more and put it through its passes. Pilou thanks for the bread crumb trails in updating NODES to get it to work.
Here is quick play
Cool exploration of form!
10649.18
Pilou - random experiments as inspiration.
Show messages: All  1-7  8-18
