FR Button to toggle snap to locked objects.
All  1-2  3-5
10648.3 In reply to 10648.2
Thanks, I thought there might be a way to do it! I do find it useful that you can see the state of the snaps as well though, which you can't with a hotkey.
10648.4 In reply to 10648.3
Hi Dodgy, here's another way you can do it, put the attached script file in the MoI appdata startup folder. On Windows it's at %appdata%\Moi\startup , on Mac it's in ~/Library/Application Support/Moi/startup .
That will insert a "Snap to locked objects" checkbox on the bottom command bar and you can either click it or you can use the keyboard shortcut to switch it on/off.
10648.5 In reply to 10648.4
Perfect! I can see I'm going to have to learn the scripting of MOI! I've written scripts for other packages, so I just need to learn the language!
Mike
Show messages: All  1-2  3-5
