Draw/Edit Rectangles from center
All  1-5  6-8
10647.6 In reply to 10647.5
Hi moritz,
> > "But when you click on the Rect button, the 2nd icon should be launched for the
> > initial default instead of the first one."
> I can live with that.
So is that part working for you ok? With the change to the ordering in Rectangles.xml do you get rect from center as the default?
If you wish to change the order of the buttons that is possible by editing Rectangles.htm . The .xml file defines what commands are in the "command set" and the first one there will be the default one that is initially launched when activating the command set. The .htm file has the UI that is displayed for that command set.
10647.7 In reply to 10647.6
Hello Michael,
I was on the wrong path:
\Users\self\Library\Application Support\Moi\commands\Rectangles.htm.
Now I have changed to
\Applications\MOI V4\MoI v4.app\Contents\Resources\commands\Rectangles.htm
made the changes and - it works!
Sorry if I stole your time.
But when updating to a new version I have to do the inputs again?
-moritz
10647.8 In reply to 10647.7
Hi moritz,
Yes for this kind of mod you'll need to apply it again on new versions.
Show messages: All  1-5  6-8
