How to close faces in this area?
All  1-5  6
10643.6 In reply to 10643.4
So what is usually the simpler way is to be more like this - start with a full solid piece (3DM attached):
Run Construct > Boolean > Difference using the line as a cutting object. That will divide the solid into 2 pieces:
Delete the piece you don't want and then it's all done, there isn't any fill in needed because a boolean cut on a solid makes solid chunks with the cutting object already combined in:
Show messages: All  1-5  6
