How to delete edges in middle of faces?
All  1  2-3
10642.2 In reply to 10642.1
Hi DrBombs, an edge like that isn't in the middle of a face, it's at the borders of a face and so you've got 2 faces there.
If 2 faces have the same complete underlying surface, or if they are 2 planes that are co-planar, then boolean union will merge the faces into a single one.
But it doesn't currently happen for 2 extrusions like you've got there. I want to make it handle that in the future though. For now if you want 2 extruded faces to be one face then yes you would need to delete them and extrude one larger face to replace them with.
What is it that you're trying to accomplish by getting rid of those edges for this particular case. Probably in your case here it's easiest to just not worry about it.
10642.3 In reply to 10642.2
Your a god send Mr Michael!
Thanks for the info, I just wanted to keep it clean because later I will make lots of cuts with booleans and such, here is a example where I am going for:
https://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=0755fdb80f01f5fff51118eea1671d67&filename=fe310ea52a03c6dc8514853585e67887.png
By Saeed Jalabi (Concept Artist)
Show messages: All  1  2-3
