Mechanisms and MOI3D!
 1-7  8-27  28-47  48-58
10641.8
Here is a great software to create these goofy gears.
https://www.gearotic.com/
10641.9 In reply to 10641.6
Thank you bemfarmer,
As you might know designing of the leafs are the most difficult part of making iris box of this type! I had to put the pivot point out of the leaf body! and later connect the pivot point via a bridge; you can see it in the below image:
10641.10 In reply to 10641.7
I will try to share my design as well after I make a video on how it could be assembled :-) (I also think I need to confess Emmett Lalish's design is way more efficient!)
but for now you can see how the 3D print works here: https://www.instagram.com/p/Cb4vUNJr_AY/
10641.11 In reply to 10641.8
Thank you WAYNEHILL5202,
I didn't know about that link! I will dig into it! :)
With what are made the videos above seen on Instagram ?
10641.13 In reply to 10641.12
Hi PILOU, With Keyshot!
https://www.keyshot.com/features/
Advantages:
It is easy to use! (Simple learning curve!)
Disadvantages:
it is subscription based! 99/month! :-(
I have plans to use Blender in the future! but for now I can use Keyshot! :-)
10641.14 In reply to 10641.13
Yep indeed it's "de luxe" animation! :)
10641.15 In reply to 10641.14
Tanx, PILOU
10641.16
Hello all,
I was able to simulate a reciprocating rack & pinion mechanism in Moi3D :)
Many thanks to Brian for his explanations as how sin function works in nodeeditor as well as James. (Thank you guys)
Note: I intentionally used two different math nodes because I thought it would prevent from having messy functions ( maybe I am wrong! )
10641.17 In reply to 10641.16
Very cool model, Psygorn!
Is the pitch line used?
Tried a slower hertz, e.g. 0.1, to see the movement.
Travel limits, and reverse may be off a bit?
Seems to have some inertia and bounce?
(Have not studied the code yet.)
10641.18 In reply to 10641.16
Hi Drillbit,
Looks great!
Wayne
EDITED: 7 Apr 2022 by WAYNEHILL5202
Size: 374.7 KB, Downloaded: 206 times, Dimensions: 458x445px
10641.19 In reply to 10641.17
Explanation: the movement is ideal ( I think in reality there would be some minor issues) according to my calculations by 1 Degree rotation of a Pinion the Track moves 0.15708 units depending on clock-wise or counter clock-wise rotation of the Pinion.
I hope this explanation helps :)
And thank you again for your explanation on how sin works in nodeeditor it helped me to have it work!
10641.20 In reply to 10641.18
Hi Wayne,
Thank you :-)
And I'd be glad to know how you made the gif?
10641.21
Hello all,
I want to share something with those of you who are interested in mechanisms and new ideas or possibly questions! As you might know, Heron of Alexandria made a sort of steam-powered machine back in his days, my question is that could it be possible to have a flying steam-powered machine based on Heron's original design?
If you take a look at here I have tried to visualize this concept: https://www.instagram.com/p/CcECaaxFnDt/ but I really don't know if physical laws will alow us to built it!
I searched the net and so far I did not find any "Heron's/Hero's flying machines" if you know that such a device has already been created I would be happy to let me know about it!
Are there any of you capable of making it? That would be awesome too!
Oh, before I forget I want to thank @Michael for creating Moi3D, Maxsmirnov ( which I hope is sound and well) for his nodeeditor, and many other members of the community in General :-) U guys rock!
Best,
Psygorn
Does your gears animations are really "physic" or it 's just simulation ?
10641.23 In reply to 10641.22
Hi PILOU,
I can say No physic engines are used! However, mathematical equations are used which makes them reliable ( I mean I can say I am sure to some degree that if you make them they will work just fine in the real world!)
10641.24 In reply to 10641.20
Making the GIF using a simple screen video capture software:
https://blog.bahraniapps.com/gifcam/
Then it is edited using this online gif editor:
https://ezgif.com/gif-to-mp4
Wayne
10641.25 In reply to 10641.23
OK that was for be sure! :)
In any case very cool result!
I will try is with the MS Physics by Anton inside SketchUp
(here nothing to do with gears just for see the "apparent" easy use :)
with gears! ;)
Here tutorials about MS Physics with gears...
https://www.youtube.com/watch?v=Vt9l3Fh2MA4
https://www.youtube.com/watch?v=s2XaEboPQ7g
esle funny ones
EDITED: 8 Apr 2022 by PILOU
10641.26
Hello all,
Do you think this device would be able to draw sin/cos ? or it will just draw zig-zag line?
https://www.instagram.com/p/CcIvMT3l4R_/
10641.27 In reply to 10641.26
Magnifical!
Depending of the Speed and Stop & Go of the vehicle! ;)
You can simulate that with Algodoo in 2D! ;) (Plot)
EDITED: 9 Apr 2022 by PILOU
Show messages:  1-7  8-27  28-47  48-58
