Mechanisms and MOI3D!
 1-13  14-33  34-53  54-58
10641.54 In reply to 10641.53
Hi MO,
I did use Aperture but it seems the leaves are rotated around the center, I mean they are not rotated around a pivot point on the lateral side of the sphere! ( I hope this explanation is good)
However, the way leaves rotate using your nodes is another type of movement which is interesting in its own rights! :-) And I can tell u it is possible to make a 3D printable design with such movement.
- Psygorn
10641.55 In reply to 10641.54
Hi
I guess you are using the "Iris_Box_3" node. I used the center point as anchor point there.
But you can see the anchor point in other nodes shown by a little cylinder.
Cool! :)
It can handle up to 60 leaves!
10641.56 In reply to 10641.55
Yes, I saw it. :-) in "Iris_Box_4 node" it seems it works fine! (Or at least I am sure with your Nodes one can make as many Iris_Dome_Box designs as he/she wants) great job! :-)
Let's make that one! :D
- Psygorn
10641.57 In reply to 10641.56
35 Leaves :)
10641.58 In reply to 10641.57
Isn't it satisfying?
Show messages:  1-13  14-33  34-53  54-58
