Mechanisms and MOI3D!
 1-12  13-32  33-52  53-58
10641.53 In reply to 10641.52
>> Is it possible to rotate the leaves using your nodes?
Yes, Change the "Aperture" value. Also, use the other blue nodes as well. E.g "Leaves", "Height"
10641.54 In reply to 10641.53
Hi MO,
I did use Aperture but it seems the leaves are rotated around the center, I mean they are not rotated around a pivot point on the lateral side of the sphere! ( I hope this explanation is good)
However, the way leaves rotate using your nodes is another type of movement which is interesting in its own rights! :-) And I can tell u it is possible to make a 3D printable design with such movement.
- Psygorn
10641.55 In reply to 10641.54
Hi
I guess you are using the "Iris_Box_3" node. I used the center point as anchor point there.
But you can see the anchor point in other nodes shown by a little cylinder.
Cool! :)
It can handle up to 60 leaves!
10641.56 In reply to 10641.55
Yes, I saw it. :-) in "Iris_Box_4 node" it seems it works fine! (Or at least I am sure with your Nodes one can make as many Iris_Dome_Box designs as he/she wants) great job! :-)
Let's make that one! :D
- Psygorn
10641.57 In reply to 10641.56
35 Leaves :)
10641.58 In reply to 10641.57
Isn't it satisfying?
Show messages:  1-12  13-32  33-52  53-58
