Mechanisms and MOI3D!
 1-8  9-28  29-48  49-58
10641.29 In reply to 10641.26
In my opinion, the mechanism would draw a zig-zag line, not a sine (nor cosine) curve,
because the rotating circle is driving the bar at a constant speed, between reversals.
The red drive gear would have to be linked differently, to a point on its circumference, so that the lateral motion is tied to the x? coordinate, to do the trig wave.
I could be wrong?
But you need WD40, and grandfathers attic collection:
https://www.google.com/search?q=sine+wave+drawing+mechanism&sxsrf=APq-WBs8yL5E1O6n_oFoVBrYLFHk7_Jwpw%3A1649523307751&ei=a7pRYoGzLeiq0PEPufqKgAE&ved=0ahUKEwjBlLqWuYf3AhVoFTQIHTm9AhAQ4dUDCA4&uact=5&oq=sine+wave+drawing+mechanism&gs_lcp=Cgdnd3Mtd2l6EAMyBQghEKABOgQIIxAnOgQIABBDOgUIABCRAjoKCC4QxwEQrwEQQzoLCC4QgAQQxwEQrwE6CAguEIAEELEDOggIABCABBCxAzoHCAAQsQMQQzoECC4QQzoNCAAQgAQQhwIQsQMQFDoKCAAQsQMQgwEQQzoLCAAQgAQQsQMQgwE6BQgAEIAEOgYIABAWEB46BQgAEIYDOggIIRAWEB0QHkoECEEYAEoECEYYAFAAWKlJYI9OaABwAXgAgAF6iAH5EZIBBDIzLjSYAQCgAQHAAQE&sclient=gws-wiz#kpvalbx=_rbpRYuWtKaLO0PEPz9WaeA22
10641.30 In reply to 10641.29
I also think it would draw a zig-zag line and not a trig wave.
10641.31 In reply to 10641.30
This video looks partly like yours, with different linkage:
https://www.youtube.com/watch?v=g3MOvsFWcd8
10641.32 In reply to 10641.31
Hi Bemfarmer,
Yes, So the car I made is called Zig-Zag car :-)
10641.33 In reply to 10641.27
From Tgoy:
Frenchy Pilou:
Your advice about using Aldodoo to build a four bar linkage was greatly appreciated. Algodoo is used find interference points of a linkage, reducing the design time before milling a part.
Thank you MOI Forum members who helped with ideas.
Regards,
Tim Goymerac
10641.34 In reply to 10641.33
Cool ;)
It's a very fun tool for 2D experimentations in many different subjects in real time !
Look this guy! ;)
https://www.youtube.com/channel/UClUIgNQOH-8WRms_awU-47A/videos
EDITED: 9 Nov 2022 by PILOU
10641.35
Hello guys,
Is there any of u who has free time and access to a 3d printer?
I want to publicly share some 3D files we made a while back.
But before full public sharing I prefer someone does a test for me and see if the 3D files are printable and the parts can be assembled and work smoothly. (I want to see if the size of the gaps between the parts are ok; because we had modified them!)
The 3d files are a type of Iris Dome Box. Note: It has thick walls so be ware it might take and consume lot of time and lot of FDM filaments!
If there is anyone who is willing to help me to discover possible issues; Please reply to this post and I will guide you on how u can get the 3d files (Pre-Public release test) and please start printing process as soon as u got the files ;-) and I will need your feedbacks so, also share them with me.
- Psygorn
10641.36 In reply to 10641.35
Hi Psygorn,
3d printer available. Its an Ender 3. How big are you going? Asking cautiously.
Run the Analysis on Autocad's MeshMixer to verify model.
Wayne
10641.37 In reply to 10641.36
Hi Wayne,
Well as I said earlier, I want to release some 3D files publicly, so anyone who is interested could use it.
for now I am in need of some volunteer help (some people with 3D printer and willing to test print the files) My intention is to figure out few things:
1- If the gaps between parts are calculated correctly (I mean the size of the gaps between parts will not create an issue for the user)
2- Discover some possible issues that I might not be able to discover myself. (so if you are going to do it, please do send me your feedback).
122 mm by 111 mm by 122 mm ( approximate dimensions of the finished model)
Let me know what your decision is?
_ Psygorn
10641.38
Here is the model that was printed for Psygorn's design.
Wayne
10641.39 In reply to 10641.38
Cool!
10641.40 In reply to 10641.38
I was finally able to download the STL files for a six bladed iris.
Note the direction of leaf opening.
There is also a different design with 4 leaves that open like trimned sphere caps on a sphere, in the opposite directions. (The hinge pins are on opposite side of the leaf.) For six leaves, the sphere opening size would be constrained by the hinge pins. 360 degrees ÷ 6 = 60 degree pin spacing. The corresponding arc length, plus pin&support radius determines the arc Length to the north pole of the dome.
A node with all leaves moving together might be possible?
10641.41 In reply to 10641.40
The North pole arc is on a great circle, whereas the sphere cap arc is not on a great circle.
The arc length between hinge pins is also not on a great circle. It is a "latitude" arc.
The different arcs are confusing. I am unsure whether or not I drew the "correct" sphere cap...
There seem to be some small differences in arc lengths...
EDITED: 19 Aug 2023 by BEMFARMER
For the sphere cap model of leaves, using a sphere of radius 10, without any overlap of leaves, nor overlap of hinge pins:
For 5 leaves, the latitude angle of the circle where the hinge pins plus support are located, is about 32.2312 degrees, from the equator.
This leave about 0.5473 units (e.g. cm) for each of the 5 hinge pins plus support.
This is about the minimum angle so that blades will not overlap the hinge pins of adjoining leaves.
For 6 leaves, there is not enough latitude circumference, until 60 degrees from the equator is reached.
At this angle there is zero space for the hinge pins.
At 61 degrees, there is only 0.0923 cm of room for 6 pins, which is extremely little.
The opening in the top of the sphere is small.
10641.43 In reply to 10641.42
Besides rotation about a fixed point ON the Sphere (and leaf), a leaf can also travel on the Sphere surface by rotation about the Sphere center.
10641.44 In reply to 10641.40
Hi bemfarmer,
Yes, indeed :-) I believe that was done by LOBOCNC (Jeff Kerr) you can search him on youtube but he claims his design is forked from Emmett Lalish's design (who made a five-leaf iris-dome box)
I think it is!
- Psygorn
10641.45 In reply to 10641.41
Hi Bemfarmer,
Could you add some photos of what you mean exactly :-)
Maybe I can help.
- Psygorn
10641.46 In reply to 10641.42
Sorry, I have difficulties to get what you exactly mean? Could you add some shapes for better elaboration?
- Psygorn
10641.47 In reply to 10641.46
Hi Psygorn
Here are ImgBox views of 3 examples:
The first image is a test image for 6 leaves, with 60 degree latitude. The arcLength of half of the (Red) sphereCap * 6, just about equals the arcLength of the Hinge Latitude.
There is no meat to mound a hinge hole.
Curiously, the arcLength of the hinge latitude is 10 * PI. There must be a reason for this?
image host
The second image is at 30 degree Hinge Latitude, with 6 leaves. The neighbor leaf overlaps the hinge area. So a guide slot is likely needed, and the hinge abandoned...
image host
The next image is with 5 leaves, with the latitude circle at 32.23 degrees from the equator. Sphere radius is 10 units.
Hinges have been placed, but no engineering has been done as to strength. This is not a final model, just a mockup.
Using the line from the sphere center, to the center of the hinge pin, as a rotate axis, permits rotation of the leaf.
In a node, six rotation axi, for the 6 leaves, should result in simultaneous opening and closing of the iris(?).
image host
The next image shows the radius of the SphereCap in Red, along with the Hinge Latitude circle. MoI quickly calculates the arc length of each.
The Red length is to be multiplied by 5, to be equal to the Latitude arclength + hinge radius*5.
image host
EDITED: 23 Aug 2023 by BEMFARMER
10641.48 In reply to 10641.47
I hope you are doing well.
What you want to do? are you going to make a 6-leaf Iris Dome Box?
Are the above showing your process of making a 6-leaf Iris Dome box?
Could u explain in simple terms what you are going to do?
the 6-leaf IrisDomeBox is shared to the public you can download it's STL files and have it 3D printed yourself :-)
There would be an instruction on how you can print an assemble it, however, you have to wait for it.
If you want to know the mathematics behind it I have to tell you, I did not find any mathematical methods out there (and I did not search for it!) to be honest I think there are some but they are not like an instruction on how one can make an Iris Dome Box with any number of leaves he/she wants.
Now let me thank @Michael :-) Because:
I have to say MOI can be used for creation of mechanisms and mechanical devices, Yes, of course it lacks some fancy features -mating feature, assembly ,etc.- of some CAD softwares such as Solidworks Yet, it's speed and intuitiviety compensates those shortcoming and here it is demonstrated that by only using MOI one can create a mechanical device such as a 6-leaf Iris Dome Box Which has no other equivalent as of yet!
Needless to say I am an ex-user of Solidworks and I believe if one wanted to make 6-leaf Iris Dome box using Solidworks he/she would reach old ages and no 6-leaf Iris Dome Box would be made!
if you search Youtube you can find 5-leaf iris dome box made by Emmett Lalish -> https://www.youtube.com/watch?v=-m8uWz-qf7Y
Later Jeff Kerr (LOBOCNC) forked Emmett's design and made a 4-leaf iris dome box of his own -> https://www.youtube.com/watch?v=pdFCBuTAVp4
there is also Brien Allison with a 7-leaf design -> https://www.myminifactory.com/object/3d-print-orbox-192727
Emmett and LOBOCNC's designs inspired the design of 6-leaf Iris Dome Box but the design of 6-leaf iris dome box is an original design! and I think as of yet it is the only 6-leaf Iris Dome Box out there! and it is designed only By Using MOI! Thanks to @Michael :-)
All in all, if I want to say it in simple words it is a show-off of MOI's capabilities in designing of a mechanical device which actually works.
This thread is made for people who love mechanisms and mechanical devices maybe they can step forth and share their designs -Made in MOI only- with us so, we can enjoy them too :-)
If you have any other questions and I can understand them I would be happy to help :-)
- Psygorn
EDITED: 23 Aug 2023 by DRILLBIT
Show messages:  1-8  9-28  29-48  49-58
