Rebuild
All  1-3  4-7
10639.4
Thanks guys
10639.5
I'm trying to add this to the UI. I've got the icon in place and the string set and it shows up, but clicking on it with a curve selected doesn't seem to fire the command. Here's the string in SidePane.htm:
What am I doing wrong?
<moi:CommandButton icon="icons/Rebuild.png" commandset="rebuild"><moi:text textid="Rebuild"></moi:CommandButton>
10639.6 In reply to 10639.5
Hi Cuboctahedron,
Instead of commandset="rebuild" put command="rebuild"
A "commandset" is one of those clusters of commands like this one for Circles:
A commandset has an XML file like Circles.xml :
<commandset>
    <command>circle</command>
    <command>circlediameter</command>
    <command>circle3pt</command>
    <command>circletangent</command>
</commandset>
And also an .htm file for the UI like Circles.htm
So in your case, having a commandset="rebuild" makes it look for a rebuild.xml that has the related commands listed in it.
Also if you just want some fixed text for the text label and you aren't going to set up translations in other languages, you can skip putting it in the Strings.txt file and omit the <moi:Text> element.
So like this:
<moi:CommandButton icon="icons/Rebuild.png" command="rebuild">Rebuild</moi:CommandButton>
10639.7 In reply to 10639.6
Ah, of course! Thank you.
Show messages: All  1-3  4-7
