Problems creating a holder for ear buds
All  1-5  6-15
10638.6 In reply to 10638.1
Don't know why, but somehow everybody seems to ignore LOFT.
3 curves, a point and presto, done...
10638.7 In reply to 10638.1
perhaps this method is ok.
Cheers Barry
10638.8 In reply to 10638.7
Quick and dirty! Love it!
But: The sides are straight.
10638.9 In reply to 10638.1
Hey Gunter,
Steve Jobs was obsessed with G2 surfacing.
A method to make those pods is to use blend. Here is a video of doing it.
Just make your outer profile and extrude a surface
Then part it and use blend. Just after the blend, you can delete the extruded surface and just mirror the blend half result to get a very smooth pill to work on.
So like what Barry shows above, just stop at the extrude and blend that top part. (The surface needs to be open) Then just use only the blend result for 2 halves.
Hope that helps.
EDITED: 27 Mar 2022 by BURRMAN
10638.10 In reply to 10638.1
Here's a version using rail revolve:
10638.11
Thank you All for your input, much appreciated.
@Michael - this looks so simple. I downloaded your file and tried it myself but I can't
seem to get how to rail revolve it the way you did.
Would you mind explaining how to do it?
Many thanks!
Guntet
10638.12 In reply to 10638.11
- pick the curve
- then the rail
- two end points of the curve as the axis
Voila.
Size: 115.4 KB, Downloaded: 35 times, Dimensions: 1010x961px
Size: 313.5 KB, Downloaded: 36 times, Dimensions: 1790x1065px
10638.13 In reply to 10638.10
Elegant!
10638.14 In reply to 10638.11
Hi Gunter, yes in a little more detail it goes like this:
Step 1 - select the "C" shaped profile curve.
Step 2 - run the Construct > Revolve > Rail revolve command (2nd icon under Revolve).
Step 3 - The prompt will say "Select rail curve". click on the closed oblong rail curve.
Step 4 - The prompt will say 'Pick revolve axis start point". Pick one end of the "C" profile curve.
Step 5 - The prompt will say "Pick revolve axis end point", Pick other end of the "C" profile curve.
In general make sure to look over at the prompt in the upper right area of the window, it will tell you what the command is expecting you to do next.
10638.15 In reply to 10638.14
Micheal, thank you very much. This is SO simple.
Much appreciated :)
Gunter
Show messages: All  1-5  6-15
