Problems creating a holder for ear buds
All  1-12  13-15
10638.13 In reply to 10638.10
Elegant!
10638.14 In reply to 10638.11
Hi Gunter, yes in a little more detail it goes like this:
Step 1 - select the "C" shaped profile curve.
Step 2 - run the Construct > Revolve > Rail revolve command (2nd icon under Revolve).
Step 3 - The prompt will say "Select rail curve". click on the closed oblong rail curve.
Step 4 - The prompt will say 'Pick revolve axis start point". Pick one end of the "C" profile curve.
Step 5 - The prompt will say "Pick revolve axis end point", Pick other end of the "C" profile curve.
In general make sure to look over at the prompt in the upper right area of the window, it will tell you what the command is expecting you to do next.
10638.15 In reply to 10638.14
Micheal, thank you very much. This is SO simple.
Much appreciated :)
Gunter
Show messages: All  1-12  13-15
