Error - crashing
All  1-3  4-8
10634.4 In reply to 10634.3
Brian, thank you for your input. I did end up redoing much of it and I think I finally got it :)
This is also dimensionally correct as I needed the diameter to be 15mm.
Thanks again!
Gunter
EDITED: 15 Jul 2024 by GUNTER511
10634.5 In reply to 10634.4
Hi Gunter,
Your object looks excellent!
Thought it might be a window, but maybe a cufflink?
10634.6 In reply to 10634.2
Hi Gunter, it sounds like you've got it worked out now? I will see about fixing up the crash.
> This brings me to my next question which is when I try to click on for example the centre of a
> circle , several little crosses show up
> so I don't know which one to click on:
Currently the best thing to do in this situation is to hide other pieces so they are out of the way and their centers won't be targeted.
A quick way to hide other thing is to select the object you want to target and then right-click on the Edit > Hide button. A right click there will do an "isolate" function where the selected objects will stay visible and everything else will be hidden. Also it will store a memory of the hide/show state before the isolate so when you trigger it second time it will restore things to the pre-isolate state.
10634.7 In reply to 10634.5
Hey Brian,
It's a prototype for a pendant for a client.
She wants the recesses to be filled with coloured
resin so super fun project.
Appreciate your interest :)
Many thanks,
Gunter
10634.8 In reply to 10634.6
Thank you, yes that's exactly what I have been doing... hiding bits that confuse me!!
Many thanks,
Gunter
Show messages: All  1-3  4-8
