Error - crashing
All  1-2  3-8
10634.3 In reply to 10634.2
It looks like there are 16 or more "centers", near the central location.
Maybe redraw the objects basic unit, and circular array, and/or mirror?
Looks hexagonal. Six sided MoI Star polygon...
I would use the origin as a center reference for a redraw. Move to first quadrant at end...
There are 12 ("invisible") micro curves at top, and 12 more near bottom, found by hiding just the obvious closed curves, and doing "lasso select" of large areas.
There are 4 semi-circles near the central "circle".
If these are deleted, and the outer rim hidden, the other closed curves extrude well.
EDITED: 26 Mar 2022 by BEMFARMER
10634.4 In reply to 10634.3
Brian, thank you for your input. I did end up redoing much of it and I think I finally got it :)
This is also dimensionally correct as I needed the diameter to be 15mm.
Thanks again!
Gunter
EDITED: 15 Jul 2024 by GUNTER511
10634.5 In reply to 10634.4
Hi Gunter,
Your object looks excellent!
Thought it might be a window, but maybe a cufflink?
10634.6 In reply to 10634.2
Hi Gunter, it sounds like you've got it worked out now? I will see about fixing up the crash.
> This brings me to my next question which is when I try to click on for example the centre of a
> circle , several little crosses show up
> so I don't know which one to click on:
Currently the best thing to do in this situation is to hide other pieces so they are out of the way and their centers won't be targeted.
A quick way to hide other thing is to select the object you want to target and then right-click on the Edit > Hide button. A right click there will do an "isolate" function where the selected objects will stay visible and everything else will be hidden. Also it will store a memory of the hide/show state before the isolate so when you trigger it second time it will restore things to the pre-isolate state.
10634.7 In reply to 10634.5
Hey Brian,
It's a prototype for a pendant for a client.
She wants the recesses to be filled with coloured
resin so super fun project.
Appreciate your interest :)
Many thanks,
Gunter
10634.8 In reply to 10634.6
Thank you, yes that's exactly what I have been doing... hiding bits that confuse me!!
Many thanks,
Gunter
Show messages: All  1-2  3-8
