Kubotek Kosmos framework inside MoI3d
All  1-8  9-11
10631.9 In reply to 10631.8
Hi mdesign,
> Thanks a lot for your reply. Do you know any more affordable kernels which could be worth to look?
The only one I know of is C3D but since that is from a Russian company it's probably not going to be feasible to use it for the time being at least. I was just about ready to spend some time doing a thorough investigation of it when the war started.
> What do you think about Open Cascade kernel (FreeCAD)?
I've looked at it a few times, it's generally not at the same level as the commercial kernels.
> Could it bring a bit better fillets/ offsets/ shelling or it`s not worth to check?
Maybe in some cases. There will be a large amount of work involved in incorporating an additional kernel though.
> I mean as addition to existing one. Something like that:
> https://discourse.mcneel.com/t/scripting-freecad-from-rhino-filletedge-case/135784
> If it is worth to do it inside Rhino maybe it`s worth to have it inside MoI3d.
I think that's about a n-sided patch surface filling mechanism which is a newer thing that's been developed in Open Cascade. So it could very well be in better shape than other things.
EDITED: 23 Mar 2022 by MICHAEL GIBSON
10631.10 In reply to 10631.9
This war is a nightmare for all points of views! :(
10631.11 In reply to 10631.9
Thanks for your answer.
Show messages: All  1-8  9-11
