Kubotek Kosmos framework inside MoI3d
All  1-3  4-11
10631.4 In reply to 10631.3
> parasolid?
I've tried with parasolid already, it's very expensive and it's quite finicky in what type of geometry can be translated into it.
So I've ruled it out once already. Maybe I should try it again at some point here if there isn't any other way.
IA like "alphago" have not yet invaded this geometric domain ?
10631.6 In reply to 10631.5
Not that I know of.
10631.7 In reply to 10631.4
""""""So I've ruled it out once already. Maybe I should try it again at some point here if there isn't any other way.""""
ACIS before parasolids. I think the challenge with acis would be more dev time on robust error handling. Its so much more open it leads to an appearance of "buggy" if error conditions aren't handled professionally...
10631.8 In reply to 10631.2
Thanks a lot for your reply. Do you know any more affordable kernels which could be worth to look?
What do you think about Open Cascade kernel (FreeCAD)? Could it bring a bit better fillets/ offsets/ shelling or it`s not worth to check?
I mean as addition to existing one. Something like that: https://discourse.mcneel.com/t/scripting-freecad-from-rhino-filletedge-case/135784
If it is worth to do it inside Rhino maybe it`s worth to have it inside MoI3d.
I`m only thinking loudly and I don`t want to start any software war.
Cheers!!!
10631.9 In reply to 10631.8
Hi mdesign,
The only one I know of is C3D but since that is from a Russian company it's probably not going to be feasible to use it for the time being at least. I was just about ready to spend some time doing a thorough investigation of it when the war started.
I've looked at it a few times, it's generally not at the same level as the commercial kernels.
Maybe in some cases. There will be a large amount of work involved in incorporating an additional kernel though.
I think that's about a n-sided patch surface filling mechanism which is a newer thing that's been developed in Open Cascade. So it could very well be in better shape than other things.
EDITED: 23 Mar 2022 by MICHAEL GIBSON
10631.10 In reply to 10631.9
This war is a nightmare for all points of views! :(
10631.11 In reply to 10631.9
Thanks for your answer.
Show messages: All  1-3  4-11
