Solid from profiles difficulty
All  1-2  3-4
10630.3 In reply to 10630.1
Hi Viewbyte, the closest that you can get to a "do it all in one step" thing would be to have curves arranged as in the attached version and then select them all and run Construct > Network.
But it's not going to be shaped well at the ends because of having too many details like the back planar slant cut and fillets baked into the profile curves instead of having those applied to a uniform starting block shape.
So the main thing is to identify the sort of "underlying block" extended shape before any fillets or cuts have been applied and focus on constructing that to start with.
10630.4
Thanks Michael, all noted.
EDIT: Once I got the network curves sorted at the back - removing that 'slice', network delivered a perfect result. : )
EDITED: 22 Mar 2022 by VIEWBYTE
Show messages: All  1-2  3-4
