Solid from profiles difficulty
All  1  2-4
10630.2 In reply to 10630.1
Hi Viewbyte, you can't really use booleans alone to build something like this, you can do it with just 2 profile views like this:
But your intent for the "third profile" looks like you want it to control the cross sectional shape of the result and not just to remove material outside of its boundary. Just using straight extrusion shapes and boolean operations alone won't have that kind of effect.
So yeah you need to use surface construction tools like sweep or network to form your shape, it isn't going to happen just with some automagic single push-button thing.
Probably it would be best to have your initial curve structure a bit more simplified, you've got things like this slanted back end and fillet pieces incorporated into your profile curves already:
Trying to include these details in the initial construction isn't good, you want the initial construction to be a simplified larger uniform shape and then something like the slanted end you cut off from the main body block with a boolean with a line and the rounded pieces are fillets that you apply at the end rather than have in the initial profiles.
So try to simplify it, make sharp corners and uniform shaping to start with and then with the simplified starting block apply cuts and then apply edge rounding.
10630.3 In reply to 10630.1
Hi Viewbyte, the closest that you can get to a "do it all in one step" thing would be to have curves arranged as in the attached version and then select them all and run Construct > Network.
But it's not going to be shaped well at the ends because of having too many details like the back planar slant cut and fillets baked into the profile curves instead of having those applied to a uniform starting block shape.
So the main thing is to identify the sort of "underlying block" extended shape before any fillets or cuts have been applied and focus on constructing that to start with.
10630.4
Thanks Michael, all noted.
EDIT: Once I got the network curves sorted at the back - removing that 'slice', network delivered a perfect result. : )
EDITED: 22 Mar 2022 by VIEWBYTE
Show messages: All  1  2-4
