script error
All  1-9  10-12
10629.10 In reply to 10629.7
I also tested on Big Sur OS 11.2.3 and it was working for me there as well.
10629.11 In reply to 10629.10
have sent an email
10629.12 In reply to 10629.11
Hi Matt, ok the problem is the script won't work well when you have units set to meters. That makes the pieces that the script makes to be very small numerically and booleans can have difficulty intersecting pieces that are too near the default 0.001 fitting tolerance.
So set units to cm or mm to use this script, then you can copy/paste it into your file with units = meters.
Show messages: All  1-9  10-12
