Design input kayak compass
All  1  2-6
10625.2
I went ahead and 3d-printed the bottom part, and laminated it in place on the kayak.
Maybe all I need to do is remove a bit of the overhang on the top part.
The design on the previous picture has kind of a straight roof on top of the compass.
10625.3
renklint I think what you have works it is just a matter of if it covers you're design requirements. Here is a simple functional design specification (FDS) that would be good to think about when guiding a design like that.
Kayak Compass
Requirements
Visible to pilot
Options
Hard Mounted or Removable?
If hard mount pierce skin of kayak or mount on top?
If removable how to retain….sticker pad, Velcro, magnets, rivets?
Shade requirement to block UV to prevent degradation lens?
If recessed how to remove/prevent water from collecting?
10625.5 In reply to 10625.2
So kindof late to the game, a change in components could have you go after a different result.
So if you were able to switch to a more Bullitt compass, like this one:
Ritchie X-21 RitchieSport Compass
Then you could create a "tunnel blend".
The angle of the kayak face and also a downward bit of slope, even adding some inset, could be a unique aesthetic design element, but also could be labeled as "structural rib" strength of sorts...
Anyway, and angled cylinder print would be easy enough to create. We could all jockey the idea if that sounded appealing too...
10625.6 In reply to 10625.5
So, like this:
Show messages: All  1  2-6
