Hi Dave, so for combining these pieces that can be done by cutting each of them with a 45 degree angled line using boolean difference, then delete the common face between them and use Edit > Join to glue the pieces together.
That's what I did to make the closed solid in the attached file.
It will be difficult to try to directly boolean them with each other because of the "barely skimming over nearly coincident surface areas" type of surface intersections that would be required for that.
If you select 2 of the pieces (be careful there's also a duplicate copy of one of them) and create intersection curves using Construct > Curve > Isect, you can see that the intersection curves are quite complex and chaotic:
