Blind stamping experts here ?
All  1-3  4-10
10618.4 In reply to 10618.3
I would start with a sharp B&W drawing such as the Goodyear image I posted. (In that example I did not re-draw it - it's just a PNG image taken from the web.)
Pull the B&W image into https://cpetry.github.io/NormalMap-Online/ and adjust the Blur/Sharp slider. That will define the softness of your Normal Map which you then apply in your render program.
You can experiment with height map grayscale images and blurring in your source image, but I think the sliders in the app are all you will need.
I also came up with a technique to make a repeating Normal Map pattern from a MoI 3D model and it worked very well. But I'll be doing a tutorial on that in early summer as part of a larger car model tutorial.
10618.5 In reply to 10618.4
Thank you.
I just compared both techniques. The 3D obviously is more realistic for
close ups (and will need those) but as you said the edges always show
up as too sharp
10618.6
Continued my experiments and you are right Ed - to achieved
this soft embossing effects normal maps do work really great.
Just in case you dont know it - "Crazy bump" is a great offline
normal map converter.
10618.7 In reply to 10618.6
I'm glad that is going to work for you. I use Normal Maps for any small lettering or repetitive detailed textures that would be time consuming or difficult to model. It's easier to modify a flat drawing than a 3D model :)
I've tried Crazy Bump, the Photoshop built-in Normal Map generator, and others. I noticed each gives a different result based on their internal algorithm, so play with them and perhaps one will work better than others for your application.
10618.8 In reply to 10618.7
Just discovered the Nvidia - looks like the fastest tool as you can
go on working within Photoshop.
Attached the latest test with Crazy Bump n-maps.
10618.9 In reply to 10618.8
That looks like the real deal! Especially with the paper (canvas?) texture over the piece.
Message 10618.10 deleted 5 Apr 2022 by MICHAEL GIBSON
Show messages: All  1-3  4-10
