Assymtetrical Chamfer
All  1-3  4-7
A screenshot...
As Michael wrote, use the checkbox to have a second field to add a second distance for your chamfer.
10617.5
Oh sorry, I meant fillet and not chamfer !
But if there is not such a function for fillet I could use
chamfer, delete the surface created and then apply blend.
Or is there any other workaround for a two distance fillet ?
Thank you and sorry again for my error
10617.6 In reply to 10617.5
Hi Tom, a 2 distance fillet as opposed to chamfer is not commonly implemented in CAD because fillets usually generate circular cross-sections and you can't make a circle that has 2 different radius values simultaneously.
So your idea of using Chamfer, deleting the chamfer face and then putting in a blend is probably your best bet.
10617.7 In reply to 10617.6
Very good and thank you !!
Show messages: All  1-3  4-7
