creating a .25 fillet around the backside of this body I'm having one hell of a time "HELP"
All  1-2  3-5
10615.3 In reply to 10615.1
Another problem is you have some fillets of a smaller radius than 0.25 already put in. Don't do that, put in largest radius fillets first and then smaller radius ones later.
Otherwise you create a situation where there is not enough space to fit your fillet as it goes around a bend that is tighter than the fillet radius.
10615.4 In reply to 10615.1
Hi jawiest, in the attached version I tuned up your curves so they were all tangent with each other
by editing the points and placing the last 2 points of each curve to be in line with each other
so the curves were tangent:
And I also removed spots where you had a bend tighter than radius 0.25 in your curve setup.
If you try to make a fillet that is larger than the space available for it to fit it will get bunched up like this:
So if you intend to make a fillet of radius 0.25 do not make any rounded areas in your profiles that are
smaller than radius 0.25 because when you then try to make a fillet of radius 0.25 going through
that area it won't have room to fit there.
With these things tuned up you can now fillet it:
Hope that helps!
10615.5
Thank you Michael for your help it's people like you and the others that make this fun to use.
John
Show messages: All  1-2  3-5
