Boolean Union is not working
All  1-10  11-15
10609.11 In reply to 10609.10
thank you so much! Your support is great, I take you as an example!
Now I definitely understand, thanks for the links to the older posts.
Sorry for my bad english by the way..
I got one more question, I will send you the data.
I want to build a rim for a bicycle. I made the rim and now I want to add little rings for the spokes. These are all solids but I can“t b. union them together.
Can you tell me why?
And second: A friend told me, sometimes it works when you start the program again. He does it sometimes with b. union problems with rhino.
With another little problem it worked with Moi3D as well. But this time not...
Michael, thank you so much and have a great day!
Koi
Size: 378.7 KB, Downloaded: 95 times, Dimensions: 1759x1410px
10609.12 In reply to 10609.11
hi Koi, it's probably because the pieces are not quite fully aligned with each other, there is a sort of really thin slivery "shelf" like shape that would need to be created by the boolean. Things involving skinny fragments like this can make things difficult for the boolean intersection calculations:
I'll take a look at it some more later to see if I can give you any suggestions.
10609.13 In reply to 10609.11
Probably the best bet would be to scale the ring pieces slightly up or down so that they will have a simpler and cleaner intersection with the main piece without any sliver thin pieces getting created.
10609.14 In reply to 10609.11
Hi Koi, here's a version with those pieces booleaned in now. I scaled the rings slightly so they had a better intersection with the surrounding geometry.
3DM file attached.
10609.15 In reply to 10609.14
Hey Michael,
I understand... Thank you so much!! Also for sending me the right object :)
Thank you again and have a nice day!
Koi
Show messages: All  1-10  11-15
