powerCone Spiral, Allometric Growth
All  1-8  9-16
10608.9 In reply to 10608.8
> trying to get the sliders and parameters to update, without success. Just get programming errors so far.
I took a look in _PowerConeSpiralGOOD16.js and it looks like to get your sliders to update dynamically you will need to adjust your event loop.
Currently on _PowerConeSpiralGOOD16.js line 572 you've got:
if ( dlg.event == 'aValue' || dlg.event == 'bValue' || dlg.event == 'zOff' || dlg.event == 'wcValue' || dlg.event == 'startAngle' || dlg.event == 'rangeAngle' || dlg.event == 'radiusAdj' || dlg.event == 'aspect' || dlg.event == 'radial' || dlg.event == 'transverse' || dlg.event == 'flat' || dlg.event == 'numpoints'|| dlg.event == 'closedTip' || dlg.event == 'Preset' )
Make it also look for slider id values in there as well, like also look for dlg.event == 'aSlider' in addition to dlg.event == 'aValue'.
Hope that helps!
10608.10 In reply to 10608.9
Thank you very very much Michael.
I'll try the changes tonight after work.
I also noticed that about line 33, function Update(...,...,...,obj)
that I have "obj" instead of "powerConeSpiral"
the "obj" isn't used, so seems to be superfluous???
Changing the "obj" to "powerConeSpiral" just caused an error...
On other scripts, like eggOvoid, with your helpful preset code, the sliders worked fine, without the changes.
So I do not understand...
10608.11 In reply to 10608.10
I checked _EggOvoid2.js from http://moi3d.com/forum/index.php?webtag=MOI&msg=10525.1 and in its event loop it is looking for Ui events of both the numeric input field and also the sliders, on line 150 of _EggOvoid2.js it has this:
if ( dlg.event == 'LValue' || dlg.event == 'BValue' || dlg.event == 'wValue' || dlg.event == 'DValue' || dlg.event == 'numpoints' || dlg.event == 'Lslider' || dlg.event == 'Bslider' || dlg.event == 'wslider' || dlg.event == 'Dslider' || dlg.event == 'Build' )
These were missing in _PowerCoenSpiralGOOD16.js, there you only were looking for UI events for the numeric input controls and not events from the sliders, that's what was different.
10608.12 In reply to 10608.11
Thank you Michael.
I should have been more careful with blithely copying and modifying code.
Which is faster?
How much faster?
Method 1:
Apex point.
50 calculated cross-section profiles, 4 * 50 numpoints each. 50 arc lengths.
Loft of said point and 50 profiles.
1 baseline for flow.
1 3D logarithmic spiral for flow.
Flow to 3D logarithmic spiral.
Method 2:
Apex point.
1 calculated cross-section profile, 4 * 50 numpoints total.
49 more profiles, scaled from profile 1. 49 + 1 arc lengths.
Loft
1 3D logarithmic spiral target for flow.
Method 3:
Apex point End.
1 calculated scaling rail curve, 50 calculated arc lengths.
1 3D logarithmic spiral, as sweep rail.
One Rail Sweep along the 3D logarithmic spiral, with the scaling rail.
Well, not sure just how the scaling rail would work. Flow would still be needed maybe, or not?
A more quickly calculated cross-section profile? (Something from Max?)
Reducing Slider parameter decimals from 3 to 2 or 1.
EDITED: 7 Mar 2022 by BEMFARMER
Here is alpha version 19.
The sliders work. Delay is roughly 1/4 to 1/3 second for one modification.
Reduced decimals of parameters to 1 or 2, from 3.
Reduced numpoints to 40, from 50.
Inner flat is working, but is on wrong side. (An easy fix, as per arcloop script.)
The log spiral preset looks a little strange. Has a variable thickness, not a curve.
10608.15 In reply to 10608.14
Well done and respect for this nice little addon the the huge toolbox of MOI !!
10608.16 In reply to 10608.15
Thank you SirTom.
When I get some time, I may try some speedups on forming the profiles.
Last night I read about how whiskers follow euler spiral curves :-) (No script planned for whiskers.)
The math guys should have tested log spirals?
Show messages: All  1-8  9-16
