messy sweep
All  1-7  8-11
10607.8 In reply to 10607.7
thanks for your explanations. I missunderstood the manual. There is an illustration that made me think that you can work with multiple rails. But now i see, that's are 2 Rails and 1 Scale Curve. I'll try it with a network. And i'll first build a clean version.
Greetings, Wolfgang
I believe that you can consider in your particular object's case the "Scaling Rail" as a third rail!
Ps You have also the middle section overlapped! ;)
else Network works like a charm : Yo have just to close the extremities by a plane if wanted!
EDITED: 4 Mar 2022 by PILOU
10607.10 In reply to 10607.9
is the solution shown by you the network-solution?
10607.11 In reply to 10607.10
Yes ;) was writed "else Network works like a charm"
but i have killed first all overlapped curves! (middle section, side edge...)
Show messages: All  1-7  8-11
