messy sweep
All  1-5  6-11
The right methods seems to do a network.
But you have to coincide points of rails and profiles to do a solid next.
Have fun !
10607.7 In reply to 10607.5
Hi wsiew,
> I really don't understand why the sweep is again messy.
It's because you're trying to use 3 rails. There isn't a "3 rail sweep", there is a 2 rail sweep and a 1 rail sweep. If you select more than 2 rails then it will do a one rail sweep along each rail so you can do something like many pipes in one go.
So your case here generates 3 one rail sweeps over top of each other which is why it looks messy, if you drag on it you should be able to see that there are 3 objects on top of each other there.
You could use Network with that curve setup or just Loft through the 3 planar profiles without any rails at all would be better because your rails are not very accurately positioned, there is a gap between them and the profile curve.
10607.8 In reply to 10607.7
thanks for your explanations. I missunderstood the manual. There is an illustration that made me think that you can work with multiple rails. But now i see, that's are 2 Rails and 1 Scale Curve. I'll try it with a network. And i'll first build a clean version.
Greetings, Wolfgang
I believe that you can consider in your particular object's case the "Scaling Rail" as a third rail!
Ps You have also the middle section overlapped! ;)
else Network works like a charm : Yo have just to close the extremities by a plane if wanted!
EDITED: 4 Mar 2022 by PILOU
10607.10 In reply to 10607.9
is the solution shown by you the network-solution?
10607.11 In reply to 10607.10
Yes ;) was writed "else Network works like a charm"
but i have killed first all overlapped curves! (middle section, side edge...)
Show messages: All  1-5  6-11
