Specifying # of points in a circle
All  1  2-3
10602.2 In reply to 10602.1
Hi Brendan, you can use the Rebuild command to help with that. It doesn't currently have a button in the UI so to run it push the Tab key and type in Rebuild and push Enter.
Then in the "Rebuild options" that will show in the upper right area of the main window, set Mode = # Points and fill in the "Point count" field.
10602.3
Ah - of course!
Thanks for that :)
Show messages: All  1  2-3
