constant distance fillet fails
10590.1
circular fillet and the others all work (see top 3 objects), just constant distance fails with the same objects at the bottom part of the screen dump. any idea why?
Size: 133.2 KB, Downloaded: 53 times, Dimensions: 837x880px
10590.2 In reply to 10590.1
Maybe the sharp angles but wait Michael answer! :)
EDITED: 16 Feb 2022 by PILOU
10590.3 In reply to 10590.1
Hi Wim, currently constant distance on curves only works between line segments.
I don't know why but get around is possible.
Just extrude it and then you can take edges which correspond what you need.
I know it's not very orthodox, but it's a trick.
Very cool trick! Bravo!
10590.6
Thanks Michael!
10590.7
Thanks Phiro, neat workaround indeed! that will solve the problem for now!
