Actual 3d patterns and problems with boolean difference
All  1-3  4-5
10587.4 In reply to 10587.1
Hi Rommo for your boolean problem as others mentioned above please post your .3dm model file.
Also as mentioned above the Transform > Array tools can be used to make repeating patterns.
For the kind of pattern in your link with every other row shifted you could use Transform > Array > Array Grid in 2 passes, like this:
You can make other kinds of repeating patterns by applying Array Dir in 2 different directions, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2612.2
10587.5
Thank you very much everyone for the help. I'm away now when I'll be home in 2 weeks I'll post the object!
Show messages: All  1-3  4-5
