Actual 3d patterns and problems with boolean difference
All  1  2-5
10587.2 In reply to 10587.1
Use the function Transform / Array X,Y with your half sphere as module!
For make a boolean difference all objects must be a solid!
So don't take a ground without thickness!
EDITED: 11 Feb 2022 by PILOU
10587.3 In reply to 10587.1
Hi Rommo,
Could you post example or your 3dm file to help finding an answer to your question on boolean issue ?
Give us more explains about your question.
Doing boolean operation on an object included in another is possible. So post your file or an example.
To do a 3D pattern you can use array function.
Have fun !
10587.4 In reply to 10587.1
Hi Rommo for your boolean problem as others mentioned above please post your .3dm model file.
Also as mentioned above the Transform > Array tools can be used to make repeating patterns.
For the kind of pattern in your link with every other row shifted you could use Transform > Array > Array Grid in 2 passes, like this:
You can make other kinds of repeating patterns by applying Array Dir in 2 different directions, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2612.2
10587.5
Thank you very much everyone for the help. I'm away now when I'll be home in 2 weeks I'll post the object!
Show messages: All  1  2-5
