How to close to make solid
 1-14  15-25
10586.15 In reply to 10586.14
Hellow all/ @Michael,
I was working on a mesh and I couldn't make a solid out of it and I don't know why, could you please take a look at it? I even tried to reconstruct it using "rebuild" script but again no Solid!
10586.16 In reply to 10586.15
Hi Psygorn, if you highlight naked edges (instructions here: http://moi3d.com/forum/index.php?webtag=MOI&msg=10582.13 ) this is the problem area:
Zooming in to this area:
That's a gap between edges there that is just a little bit too far apart to be joined together.
The top looks like it's ok it's the bottom where the pieces are not close enough together to be joined.
10586.17 In reply to 10586.15
Hi Psygorn, I've attached a version of your object here that is a solid now. I deleted the faces around that problem area, did an "untrim" to remove the current trim boundaries that were kind of messy with a couple of little edge fragments in them, then lofted between the 2 semi-circles, joined those pieces together and then used Construct > Planar to cap off the flat pieces.
10586.18 In reply to 10586.16
Ok, Thank you so much.
10586.19 In reply to 10586.17
Thank you Michael,
I was able to repeat the process.
However, I want to ask you something do u know if I a mesh which is joined surfaces and pretty small gap is printable or not?
10586.20 In reply to 10586.19
Hi Psygorn,
It depends on the particular situation but probably not.
It's more of a problem than just a gap - the triangulation generated for the STL file will not have watertight synchronized vertex structures across the unjoined edges.
Maybe some slicers could tolerate that but I kind of doubt it.
10586.21 In reply to 10586.20
Ok I see. Yet I can say that I had experienced it before (one time I had a STL file and it was not water tight but the printing machine was able to print it! However, I have to say I did not discover the mistake until the piece was printed. I think I got lucky!) So, as u mentioned I think it depends on the situation and I can say it is safe to have the 3D model water tight.
Thank you for your support.
10586.22
Good day Michael.
I finally got some time work back on this.
Since I wanted a 2mm edge so I have projected a closed curve on the model so I could get the desired lines.
And then try to sweep it but I could not get a solid out of it. pls help.
see attached file.
Thank you!
10586.23 In reply to 10586.22
Hi Matadem, the curves to sweep in your attached file are not suitable for making a solid just by themselves. It would be too thin at the ends and be essentially the same as a self intersection in those areas.
To incorporate this into the main model you would sweep to build just a surface and then trim away surrounding areas to make a place to join it in.
I've done that with the model that I attached in the above post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10586.14
Was that finished solid that I posted there not suitable for what you need?
10586.24 In reply to 10586.23
I did another try here
2 small rectangles at the end a bigger one in the middle which the rails goes into the middle of it...sweep then move this whole solid into my model pushing the other half into my model.
That seems to work but probably not the best or efficient way to do it?
Michael what you shown me was extremely useful, the reason I wanted for a 2mm thickness so it could be easier to sand when fitting the 3d printed item.
10586.25 In reply to 10586.24
Hi Matadem, that looks like a pretty good method. The only thing I'd be a little worried about is if the ends that are just barely skimming over the surface area on the main piece can be booleaned in or not. Surfaces that just barely skim over each other can tend to be difficult for booleans.
But if it worked out ok for you then that's great it was not a problem in this particular case.
Show messages:  1-14  15-25
