Random Points on a curve or UCS text
 1  2-21
10585.2 In reply to 10585.1
Hello Grendel,
For the first part of your question, I believe @Michael intentionally avoided it ( Showing coordinates of the points beside them) I believe he mentioned it would be too messy.
For the second part of your question, I was not able to understand what u mean?
10585.3 In reply to 10585.1
First question = yes there is a script for that. I'll get it posted in a bit.
10585.4 In reply to 10585.2
Psygorn,
See image for what I was looking to do.
10585.5 In reply to 10585.3
Burrman, thanks for the help
10585.6 In reply to 10585.1
Hi Grendel,
> First is there a script to label points with their coordinate data as shown on the left? I can manually do this but for allot of points that becomes undesirable. Ability to display them in a table would be even better or at least paste them to one.
You might find my Coordinates script to be of some help: https://moi3d.com/forum/messages.php?webtag=MOI&msg=10013.1
--Larry
You have distort curve by Max Smirnov
10585.8 In reply to 10585.4
Hi Grendel, for your "points on path" one, initially set up a line with a straight array of points on it, apply randomize (http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5), and then use Transform > Deform > Flow to map the points from the straight line to the curved path.
10585.9 In reply to 10585.1
Hi Grendel, for labeling points, try the attached script which will generate label annotation text positioned on selected point objects:
10585.10
.......and this right here is the reason that everyone loves this software, community and developer. I can't thank you all enough for the assistance and Michael for your time that you give to us when we can't figure something out or do not fully understand a tool or construction methodology
I don't remember if exist a plug for convert "Control Points" in simple geometric "Points" ?
You can use show points on your curve.
Then select the points and copy/paste to have the points.
Is it what you needed ?
10585.13 In reply to 10585.12
@ Phiro
No! :)
If I draw a cube, then Show Points then select these points
it's "control points" not geometric points !
They can't be labelled by the "LabelPointsCoordinates" command of this thread!
OK,
but if you copy/paste the points you can use the script.
No ?
10585.15 In reply to 10585.14
No if you copy the "control points"!
It's the problem! :)
I don't understand.
Your goal is to use the script LabelPpointCoordinate ?
I think, it works.
First you have a sphere (for the exemple).
Next, Show points
Next, you select your sphere and its control points.
Next, you deselect the sphere, only control points are selected.
Copy/paste give you the points.
At this moment, points are only points and you can use the LabelPointCoordinates script.
It's what you wanted or I missed the goal ?
10585.17 In reply to 10585.16
Yes exactly that but till now i was not able to separate the Points on the copy past!
I must miss a step on the process!
Even a simple cube : sometime that work sometime not!
I have not yet found the little detail where i make a false operation
on the unselect object / Points!...must be evident but...
It's the maze of the day! :)
EDITED: 14 Feb 2022 by PILOU
10585.18 In reply to 10585.17
Hi Pilou, maybe you were missing the step of selecting the points?
You can select all control points of an object by first selecting one and then use Ctrl+A / Select all.
10585.19 In reply to 10585.18
Yes but when i move this selection sphere comes also! :)
idem with the one point selection + CTRL + A
here the selection of points then deselect the sphere
I must miss something trivial...
I think I have found! I forget to copy Past in place the selection! :)
Eureka!
So no need a convertor Control Point : to Geometric points! :)
Thx for all!
10585.21 In reply to 10585.20
Hi Pilou, yes to convert control points to "standalone" point objects you need to select them, then use Ctrl+C copy and then Ctrl+V paste.
Show messages:  1  2-21
