Offset calculation fail
10584.1
Good day.
I am trying to do an offset on an odd shaped part and it gives me calculation failed.
the only way I could get a offset line out of it is to draw a small line and the desired distance and sweep it.
Attached the file.
Is there a way to offset or where are my problems?
Thanks!
10584.2 In reply to 10584.1
Hello Matadem,
I am able to get offset ( I tried 1-10 units)
Edit: pleas be more specific you want to have offset over an edge? or the surface?
10584.3 In reply to 10584.2
Yes I should have been more specific. on the attached pic the highlighted line with green arrow would not offset inwards.
Outwards had no problem...the only solution I could come out with is 2 draw a small line (red arrow) and sweep around.
Funny thing is I have reopened the file and the offset works now :/
Could it be my struggling laptop? Dell xps 8gb i5?
Thank you!
XG.
Size: 108.4 KB, Downloaded: 29 times, Dimensions: 506x616px
10584.4 In reply to 10584.3
Hi Matadem, your curve here was just very slightly off from being planar, that might have something to do with it.
