Flow issue
All  1  2-5
10583.2 In reply to 10583.1
Hello Matadem,
Is this what you want? (For flow I think you have to choose the right edges, and I suggest you try it click close to the edges that are similar together, I did this by clicking on the width of the base surface and then the width of target surface then mirrored the created shape) Of course @Michael can explain it better.
10583.3 In reply to 10583.2
I have just made 2 lines...because i tried it with lines and surfaces.
Just right now I made 2 lines but longer that the objects and it worked! I guess I thought it would stretch to exact measurements that one of the reasons I did not try bigger reference surfaces and lines.
Tnx!
10583.4 In reply to 10583.1
Hi Matadem, the problem is that your object is located too far away from the base plane. When you do the flow that same distance to the base plane will be evaluated along the target surface's normal and when that distance is large it will tend to get bunched up or spread out awkwardly.
To fix it position the object right on the base plane instead of having so much space between them.
There's a recent post here that describes this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10577.4
10583.5
Thank you! Item is already printing :D
Show messages: All  1  2-5
