Problems running under Wine
All  1-3  4-7
10581.4 In reply to 10581.3
Hi albertosaurus,
> I recall seeing in the release notes for one of the betas that there's a setting to control texture
> formats, but I can't find any documentation. Is that a worthwhile avenue of investigation?
Hmmm let's see - that was for some driver that sent back colors in reverse byte order than expected. A little bit later I added in a readback test done at startup to detect this situation automatically but it can be manually turned on by adding in an entry in moi.ini under the [View] section:
[View]
TextureReadbackSwapRB=y
If it doesn't help remove that line again.
There is one other thing I can try, there is a variation in how readback works when on Mac OpenGL. I'll make a test version to send to you that uses that method for Wine/Windows OpenGL as well and see if that does any good.
10581.5 In reply to 10581.4
That broke selection completely. I believe it's a positive sign that we're on the right track as to the root cause.
Thanks for all your help!
10581.6
Addendum: Creating an annotation under Direct3D manifests the same text rendering corruption as a the rest of the text in the viewport.
10581.7
Problem solved! Thanks Michael for all your help. The absolute gold standard of excellence.
Show messages: All  1-3  4-7
