Flip script and height bump/map script
All  1-9  10-14
@ Matadem
About the first post maybe you can use this by Max Smirnov! ;)
10578.11 In reply to 10578.9
@ Psygorn
I have not tested but from the example of the Inset function (from my site) seems you can chain parameters inside the function!
Inset thickness=2 direction=Outwards expand=false grooved=false useseparateheight=true height=4
and at the end you make a shortcut of all the line! ;)
Must be the same for the Fillet!
So... :)
this line inside the shortcut option et voilĂ  !
chamfer 2 distanceinput1=1 chamfer distanceinput2=2
and you obtain directly a Chamfer with 2 different distances! :)
Here my shortcut was Alt + H, distances was pre-defined by the line!
EDITED: 5 Feb 2022 by PILOU
10578.13 In reply to 10578.8
Hi Matadem,
> On the Fillet and chamfer topic I always thought It would be nice for instance if you are in the
> fillet command with your lines or your items selected
> That shows you the fillet numbers range that would work, example between 5mm and
> 50mm ...outside the range it would be a calculation failed.
Unfortunately it would require quite a lot of number crunching to figure that out. Probably some kind of specialized solver for intersections between offset surfaces would be involved.
So there would probably be some kind of long 10 minute hiccup when you started the Fillet command before it would have that information and be able to proceed with the command.
10578.14
Got it! tnx to all
Show messages: All  1-9  10-14
