How to properly use the Network tool
All  1-3  4-8
10576.4 In reply to 10576.1
Basically a single surface like Network is going to generate should be more like a single shape in a broad sheet. If you have tight bends those are transitions between broad sheets and it will be difficult to form them well if you try to "bake" them all at once into a single surface like Network will generate.
Usually it is best for tight bend areas to be done as fillets that transition between separate surfaces.
Additionally trying to use Network to do the whole shape as one single surface will also need a "pole" in it and it can be difficult to avoid visible evidence of the pole structure in the shape as curves collapse down to a single point.
10576.5
Hello Michael,
I hope you are doing well.
I've got a quick question for you. Could we trust and assume a sealed joined surface object as a Solid one (A joined surface object without any open holes)?
And I noticed something! ( I had an object; Moi3D said it is a joined surface I saved the .3dm file as it was and opened it again now Moi3D says it is Solid) which of course is what I needed but it was kind of a surprise for me.
10576.6 In reply to 10576.4
I think I'm starting to understand it better. Thinking about Network like a blank sheet simplifies my understanding and explains why it gets distorted as the shape gets more complex. I will try to approach designing this object differently.
Thank you very much!
10576.7 In reply to 10576.5
Hi Psygorn,
There are actually 2 conditions that MoI checks for to give an object the designation of "solid" - that it has all joined edges and also that it has at least 2 volumetric regions in it.
There is probably some kind of anomalous geometry in the object like a degenerate face that is squished flat like a line or areas of the model that self intersect. Such things can cause inconsistencies in volumetric analysis for determining regions.
10576.8 In reply to 10576.7
I hope you are doing well,
Thank you for your reply.
Show messages: All  1-3  4-8
