Filling polygon
All  1-3  4-13
10571.4 In reply to 10571.2
Tricky (if I got your proposal?) :)
But the shape isn't fully symmetric (there is a reason that it has to have exactly that shape).
Isn't it possible to just fill any polygon somehow?
10571.5 In reply to 10571.2
Ah, now I got it, thanks for the video!
Great, didn't know that sweep can do from-to this way - very helpful, thank you!
10571.6 In reply to 10571.3
Thanks Michael, now I have two ways to achieve what I couldn't do a minute ago :)
10571.7 In reply to 10571.6
A 3rd way is to get the long sides as individual curves and then use Construct > Loft to build a ruled surface between them.
10571.8 In reply to 10571.7
^^Neat! Thought loft is only 2D->3D, good to know it can also make faces!
10571.9
Was also able to extrude the resulting face now for 1 mm with the "Shell" tool. Don't understand why "Extrude" did just nothing though (would perhaps be helpful to give some textual hints which expectations of a function are not fulfilled instead of doing nothing). But got this working for now :)
10571.10 In reply to 10571.9
Hi NaN, Extrude can work on curves or individual surfaces but not on an object made up of multiple joined surfaces.
10571.11 In reply to 10571.10
Ok.(..) Still have to sync my expectation better to the way how things work in MoI. A lot is possible - just often not as I would expect. :) But that's ok for somebody who is still scratching the surface when it comes to actual modelling in MoI. (Am using MoI almost daily - but only as a super fast STEP viewer)
10571.12 In reply to 10571.11
Hi NaN, there is some information here for people coming from a poly modeling background:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
A couple of things are - try to use 2D profile curves and cutting things using boolean operations rather than trying to patch in surfaces on a 3D wire scaffolding and it's more common to construct things directly in place instead of say starting with a box and mutating its points into some other shape.
10571.13 In reply to 10571.12
Thanks for the links, will have a look!
Show messages: All  1-3  4-13
