whale
All  1-4  5-9
10568.5 In reply to 10568.3
Hi Mala,
> It is that the shape is "hanging over".
That's sort of the basic nature of this kind of tranformation, the shape will expand like this, and the further away from the base level the wider the expansion:
EDITED: 28 Jan 2022 by MICHAEL GIBSON
10568.6 In reply to 10568.3
Hi Mala, I'm not sure if this is what you need but it is possible to use Construct > Curve > Silhouette to make a mold "parting line". You can remove an area of undercut with it.
Construct > Curve > Silhouette can generate these using "Top" as the projection view will generate these curves:
Trim the surface with the silhouette curves:
Project the silhouettes and extrude the projections:
Trim extrusions:
That will cause the shape to drop straight downwards with no area "in shadow" :
10568.7 In reply to 10568.6
i guess it is a smart idea. Thank you!
I cannot reconstruct the workflow. Do you initiate it at the already attached tow-finger part?"
And do you do it in the top view with the top option choosen?
Maybe you could share the 3d file?
10568.8 In reply to 10568.7
Hi Mala, it starts with the file you posted above, "hand Moi Forum Shown.3dm".
Open that file and select this surface:
Then run Construct > Curve > Silhouette:
In the command options choose "View: Top" and then push "Done" :
That will generate these curves:
Just these 2 are used, you can delete the others:
Then it's Trim the surface by those silhouettes, Construct > Curve > Project to project the silhouette to the construction plane, then you can either loft between the silhouette and projection or extrude the projection and trim it. Let me know if you need more step-by-step for these parts.
3dm file attached.
10568.9
Hello Michael,
fine, this workflow. I was able to do it. I wasn´t fully happy. Because this is a Logo of a product and it needs to be as near as possible on the original shape.
My workaround seemed to work also. Must wait was the milling company says - but I hope it will go on with my version. I didn´t bend/flow/attached the hand not anymore on a half circle segment. I made a quater segment. And now I got a much better result - not fully perfect...I will see...
Here a first prototype of a former try...
Thanks and best regards...
Show messages: All  1-4  5-9
